home made horse power
Car: 1989 TRANS AM GTA
Engine: 355 L98
Transmission: Built 700r4
Axle/Gears: BW 3.27
I was thinking about welding a piece of aluminum to the runners on the inside then cutting the runners out of the middle and welding another plate on the outside and basically making them one big runner with the plenum and lower intake being siamesed also i was hoping this would help me make power to 5500 and gain some upper rpm power what do you guys think?And yes i used the ''SEARCH'' button but couldnt find anything about what i want to do so please no stupid comments..thanks
Re: home made horse power
I have seen it done on here before, not sure where. But the guy used SLPs runners to do it, however it does make some good horsepower. I just dont know whats going to happen to your torque.
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
Basically what you are suggesting has been done a few times. However you need to do some research as to how long your runners need to be. There are formulas floating around. Try www.wallaceracing.com/calculators.htm
I bet you will need something around 13-14 inches of runner for you goals. This includes the heads. Don't even think of using the stock intake manifold.
Search under "siamese runners" and you should find a lot of information.
Car: 1989 IROC-Z
Engine: 5.7L EFI LTR setup
Transmission: T-5 World Class
There is a guy on here who made power their .... He siamesed his runners . But his big gain came from the extrude honeing of the base ( not siamesed) ...he went to 45mm I think . He was still well into the powerband at 6000 rpm. My graph makes power all the way to 4900 solidly ...and barely falls off. But that was not tuned and running a stock vette bin file ( APYP)
Engine: 355 L98
Axle/Gears: BW 3.27
Car: 1989 GTA
Engine: 369 TPI
I see no advantage to what you are trying to do. What you are doing is making one huge plenum down to the intake manifold.
What you found out in your search is others have just joined the two runners and in that manner have extended the plenum to the manifold or just short of it with some runner remaining.
What needs to be done is to find out how long the runner(s) needs to be for your combination and go from there.
Car: 1989 GTA
Engine: 369 TPI
Madmax did not have one piece runners as the poster is proposing to do.
Car: 87 Iroc
Engine: modified 350
Transmission: high performance built 700R4
Axle/Gears: Strange S60 3:73
One of the best upper RPM tpi builds I have seen was a guy who took a set of SLP runners cut them in half and fully siamesed the top half then welded them back together. He also siamesed the upper plenum.This effectively increases the plenum to make it breath .It also keeps the tuned port effect .He ran 12.2 in the quarter mile with a mild 350.
Engine: 355 L98
Axle/Gears: BW 3.27
I would love to do that to better runners but my plan is to do it a cheap as i can and fab as much as i can also,thats why i keep pushing the stock runner issue.I wonder how that same mod would do with stock runners and a heavlly ported base?thanx for the great idea.....
Car: 86 Omni GLHT
Engine: 2.2 Turbo/Intercooled
Transmission: 5 speed
Axle/Gears: 3:85
i think it will work. i use homemade **** all the time and it works. some people just like buying expensive **** and saying that your homemade **** won't work to make themselves feel better. i say go for it and hit the dyno to prove it works. i bet you gain a **** load of power if the runners are big enough.
Engine: 355 L98
Axle/Gears: BW 3.27
Roach thanks for the positive words,some people just dont understand that that the aftermarket came from people that didnt want to buy parts for what ever reason so they built there own,there not always as pretty but they can still look good and perform just as good sometimes even better (if your good) as the name brand stuff
