Any problems using this plenum/runner combo?
Old May 19, 2007 | 07:18 PM
SS ninja's Avatar
Engine: 5.7 vortec crate w/TPI
Transmission: 2004r
Would I run into any problems using runners that have the cold-start injector with a SD plenum/throttle body?
I've currently got a complete SD setup, but a guy local to me sold me a near mint set of TPiS runners that have the cold start injector for $200.
If I block off the cold start injector at the bottom of the runner, would I be fine? Can these runners only be used with a plenum from a cold-start car?
Old May 20, 2007 | 10:15 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Re: Any problems using this plenum/runner combo?
Plug the hole and you'll be fine.
Old May 22, 2007 | 03:17 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Just make sure your chip is calibrated to accomodate whatever method you choose. If you need a cap to plug the back of the fuel rail, PM me.
norcalz28
Northern California
26
Dec 7, 2016 12:49 PM
andy74
Sep 3, 2015 08:41 AM
GeneralIesrussi
Sep 3, 2015 03:23 AM
greenyone
Sep 2, 2015 03:39 PM
z28guy134
Sep 1, 2015 11:50 PM
