can i run this cam
Old May 20, 2007 | 02:36 AM
88fastgta's Avatar
Car: 1988 Flame Red Trans am GTA
Engine: Forged 355 4 Bolt, FIRST TPI
Axle/Gears: ls1 torsen 3.42 gear
can i run this cam
i found this cam and i was wondering could i use this in my engine.. the lift is pretty close to what the stock heads can take and very similar to what the powermax 2032 cam would have at 1.6 rockers..... what do i need to run this.. its a comp cam and according the the camshaft article on third gen.org it says that its an factory replacement camshaft.. so i should work.... right and how would this camshaft sound.. would it be any better than the powermax 2032 cam....
i have an 1988 pontiac trans am gta with the 350 engine...
http://www.compcams.com/Technical/Se...umber=12-416-8
Old May 20, 2007 | 03:20 AM
ws6gta89's Avatar
Car: 1989 TRANS AM GTA
Engine: 355 L98
Transmission: Built 700r4
Axle/Gears: BW 3.27
Re: can i run this cam
I dont think stock springs can handle that but i might be wrong but i would get new ones if you did get that cam just because of how old they are and that is alot bigger than stock check your resource's again....good luck
Old May 20, 2007 | 05:53 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Too much lift for stock clearances between the bottom of the retainer and the top of the guide boss. In order to run that cam, if it were my engine, I would have the guide bosses milled down and/or run +.050" retainers/locks.
Stock springs suck. Period. They're about as weak as anything. I would change out stock springs for stock springs even if the rest of the motor is stock. If a cam is changed, I would definitly change out springs. Crazy not to. Did I mention stock springs suck?
Old May 20, 2007 | 10:15 AM
88fastgta's Avatar
so all i need is some new springs... what kinda springs do you recommend stekman
Old May 20, 2007 | 01:44 PM
mnorton's Avatar
Car: Red 1987 IROC Convertible
Engine: 305 LB9 TPI
Transmission: T5 5-Speed
Axle/Gears: 9-Bolt 3.45
Recommended Comp Valve Springs are 986-16
Old May 21, 2007 | 06:31 PM
roachjuice's Avatar
Car: 86 Omni GLHT
Engine: 2.2 Turbo/Intercooled
Transmission: 5 speed
Axle/Gears: 3:85
i had stock springs on a 502/510 lift cam and ran the hell out of the car. never had a problem.
Old May 21, 2007 | 09:13 PM
tenpin842's Avatar
Car: 1987 Trans Am
Engine: 5.0L TPI
Axle/Gears: Richmond 3.73
I changed my springs....while your in there...its worth it.
Dont forget to change your valve seals!
Frozer!!!
Jan 19, 2024 04:55 PM
midge54
Dec 27, 2019 04:14 PM
camaro71633
Sep 1, 2015 10:24 AM
1988iroc350tpi
Aug 14, 2015 07:52 PM
355tpipickup
Aug 13, 2015 07:35 AM
