Please Help
Old May 27, 2007 | 07:53 PM
formula_novice's Avatar
Car: 1989 Firebird Formula
Engine: 383 Stealth Ram
Axle/Gears: 3.73 9 bolt Posi
Please Help
Hi Everyone,
Since rebuilding my 350 TPI (see signature), I'm having trouble getting it to idle steadily. Right now, it will surge randomly between about 500 and 900 RPM. In effort to troubleshoot, I have done the following...
I installed an AFPR and the pressure is now at 48 PSI. I also installed a new IAC sensor, cleaned the IAC passage, and tried adjusting the torx idle screw. The TPS sensor has also been adjusted to 0.62. Sadly, none of this has fixed the problem and I am at the end of my limited knoweldge
Any info would be greatly appreciated.
Thank you!!!
Old Jul 9, 2007 | 09:48 PM
sergio's Avatar
Car: 91 T-am convertible
Engine: 5.0 TPI
Transmission: 5 speed manual
Re: Please Help
Hello,
Did you ever fix your problem? What was it? I have a similar problem "surging idel" when engine is warm.
Old Jul 10, 2007 | 03:55 PM
TPeye's Avatar
Car: 1992 Camaro Z28
Engine: 350ci
Re: Please Help
First, try setting the tps to .54 volts. When you adjusted the idle with the torx screw, did you follow the factory procedure? I would also make sure all the grounds are clean and secure, and make sure there aren't any vacuum leaks.
Old Jul 10, 2007 | 06:03 PM
thunder85's Avatar
Car: 1988 firebird trans am GTA
Engine: 5.7L w/hsr
Axle/Gears: posi 3.23
Re: Please Help
if your system uses a MAF sensor, replace your maf power and burnoff relays. cheap, and usually a good part of the problem. another sensor that confuses things and makes for a messed up idle is the coolant temp sensor. this especially comes into play when the vehicle is warm.
on a side note, u also might want to get one of those obd1 scanner cables for a laptop. they are around 40 and let you watch all your sensor values realtime so you can see which sensor is out of range or malfunctioning. exceedingly helpful
Old Jul 11, 2007 | 12:45 PM
Re: Please Help
Hi Everyone,
Sorry, I haven't been on the board for a while. I'm still having the problem. I've adjusted the torx screw both with the TPS at .54 and .62. I also removed my air foil (and left it off) and cleaned the IAC passage.
I bought a cable from Moates and hooked it to a laptop, but the software seems to work when it wants to.
Any further suggestions would be appreciated.
Thanks!
Old Jul 11, 2007 | 02:59 PM
LoneStar666's Avatar
Car: 2005 Pontiac GTO
Engine: 364ci LS2
Transmission: 6 speed
Axle/Gears: 3.46
Re: Please Help
the torx screw for the idle, turn it out a little more to make the idle a little higher...
also, check for vacuum leaks... get a can of carburator cleaner and spray it around on various parts of the intake with the engine running, if the idle changes at all you have found your leak.
Old Jul 11, 2007 | 05:37 PM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Re: Please Help
DON'T mess with the idle torx screw unless you absolutely have to. It's just a band-aid fix. I don't believe a ZZ4 cam requires an idle adjustment.
Find the problem, don't just hide it.
Old Jul 12, 2007 | 07:40 AM
Re: Please Help
Thanks for the replies!
I tried adjusting the torx screw both directions and it didn't seem to help.
I don't know if it is related, but when I turn the motor over I hear a loud pop/click sound. It sounds like its coming from the passenger side to me. Usually on the 3rd pop, the motor will start up. Could that be an exhaust leak?
Old Jul 12, 2007 | 09:58 AM
Engine: 364ci LS2
Axle/Gears: 3.46
Re: Please Help
i dont think anyone can tell you without being there with the car....
does the "pop" stay with the car when its running? or just when you are cranking it over?
