Schrader valve question
Old May 28, 2007 | 01:47 PM
pinky93's Avatar
Car: 1989 IROC-Z
Engine: 5.7
Transmission: 700R-4
Axle/Gears: 9-Bolt Borg-Warner 2.77
I am hooking up an Autometer electric fuel pressure gauge and wondered if I should gut the schrader valve and use a 4AN to 1/8"npt adapter to connect the gauge or remove the schrader valve altogether.
Also, take a look at the picture I have attached...do you think I could tap in here to get vacuum/boost?
Thanks!!
Old May 28, 2007 | 08:58 PM
glock's Avatar
Car: 1989 gta
Engine: L98 D1SC procharger twin IC
Re: Schrader valve question
yes you can tap your boost there
Old May 29, 2007 | 05:19 AM
pinky93's Avatar
Car: 1989 IROC-Z
Engine: 5.7
Thanks!! How are you coming with your belt?
Old May 29, 2007 | 06:22 PM
glock's Avatar
Car: 1989 gta
belts is good just order tires and msd 6 btm should be here this week.. how far are you along on the d1sc install?
Old May 29, 2007 | 06:27 PM
pinky93's Avatar
Car: 1989 IROC-Z
Engine: 5.7
Once I get the gauges in, then I need to dyno it and I would like to run it at the track once also. Then we are diving in. I know what you mean about the MSD BTM...I want one!
Hey, how did you hook up your fuel pressure gauge? I am thinking I need an adapter from the Autometer sending unit, which is 1/8" npt and then gut the Schrader valve, whcih is 4AN..... or maybe the the Schrader valve comes out?
PS - I want some pics of your install!!
Old May 29, 2007 | 07:23 PM
glock's Avatar
Car: 1989 gta
not to sure about the fuel pressure gauge .... i just need a few finishing touches and she is done ...i have taken it out a few times and open it up
Old May 29, 2007 | 07:46 PM
pinky93's Avatar
Car: 1989 IROC-Z
Engine: 5.7
How did she feel?
Old Jun 1, 2007 | 06:34 PM
pinky93's Avatar
Car: 1989 IROC-Z
Engine: 5.7
C'mon people.....someone knows the answer to this question!
Old Jun 1, 2007 | 06:54 PM
PneumaticTire's Avatar
Car: 1986 Camaro Z28
Transmission: Who orders an auto in a Camaro??
Axle/Gears: Economy gears..once again, WHY?!?
If it's just a matter of untwisting the old schrader valve, and installing the one that came with the kit, just swap it. That's just me though. I am a firm believer on using what the part was designed for. You could do that quicker then it takes to open this sites homepage...
Nice IROC BTW.
Old Jun 1, 2007 | 07:08 PM
pinky93's Avatar
Car: 1989 IROC-Z
Engine: 5.7
Nice IROC BTW.
OK, I just wasn't sure that I could actually unscrew the schrader valve....thanks for the info. I agree with you on using the designed part for the job. I have had some tell me to gut the schrader valve, so I was confused.
Also, thanks for the compliment!!
Old Jun 2, 2007 | 09:43 AM
5.7iroc-02ws6's Avatar
Car: 1988 IROC/02 WS6
Engine: zz3 crate w/12 psi ATI and stock ls1
Transmission: 700r4 w/2800 stall and m6
Axle/Gears: 3:42 10 bolt-both cars
I used a valve stem tool and removed the inner core of the schrader valve and then tapped into the schrader valve... worked good on two cars...
I used the same fitting for boost too...
Cameeeero
Sep 18, 2015 04:00 PM
SLNTSCPE
Aug 22, 2015 09:15 PM
1985chevydude
Aug 20, 2015 12:29 AM
R3500
Aug 17, 2015 12:16 PM
redmaroz
Aug 16, 2015 11:40 PM
