Does anyone know if the Accel 58mm tb will work on all years?
Car: 90 IROC
Engine: 406
Transmission: GMPP 93/4L60
Axle/Gears: 9 bolt 3.27
85-92....I read somewhere that the Accel piece will work on all years by changing the throttle bracket. I have a chance to buy one for a good price The tb is from an 88 model my car is a 90. will it work? Im going to give Tim at LPE a call when they open. Just wondered if anybody knows.
Thanks,
Mike
Black 90 IROC, L98, A4, 323 gear. SuperRamed 406 in the works!
[This message has been edited by MikeH (edited September 15, 2000).]
Thanks,
Mike
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
I dont know for sure, but I do know the years are 85-88, and 89-92. Judging from that I'd say it wouldnt work. I dunno how difficult it is to change the throttle bracket.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
1991 Camaro Z28
13.25 @ 107.18 MPH
Southern California
Car: 88 Monte SS
Engine: Super-rammed L-98 383
Transmission: T-56 6-Speed
Axle/Gears: 8.5" G-BODY G-80 3.73
To add to this, you will have to change the THROTTLE CABLE since they are different. I bought a like new 89-92 58MM ACCELL for $300 that I use on my car, and I also use an 89-92 TPI throttle cable. HTH's
88 Monte SS 355 TPI/LT-4 HOT CAM/AFR Hydra-rev/ T-56 6-Speed
Car: 90 IROC
Engine: 406
Thanks for the help everyone!
88SS6SPEED...Thats what i was told this morning you did the reverse of what IM trying to do. Did you have any problems with the TV cable connection? would i need to swap that also?
BTW...Thanks for the tip on the Walbro pumps!
IM seriously thinking of buying a new one from summit. I dont know by the time i buy a new cable and swap them out.
Car: 88 Monte SS
Hey Mike, back when I had the 2004r in my car, I used the TV cable from a 90-92 tpi with 700r4. I think that the TV cables are the same, all the T.B. have the same TV cable hook-up connection. The 85-88 and 89-92 TPI throttle cables also hook-up the the GAS PEDAL the same way, the ONLY difference is the end that differs from 85-88 to 89-92 TPI. So, you should be fine once you get the correct cable for the particular T.B. No problems on the WALBRO PUMP info, glad to help a fellow car guy. SS-ya
Car: 90 IROC
Engine: 406
88SS6SPEED...Thanks for clearing that up I think I finally understand the differences between the two.
I didnt end up getting the Accel unit though. I bought the BBK/Edelbrock one from Summit. IM hearing good and bad about them.
Mike
Mike
9192camaro
16
Feb 3, 2019 12:21 AM
