what motor do I have????
Old May 31, 2007 | 07:33 PM
hung4wheeler's Avatar
Car: 87z28
Engine: 70 LT1
Transmission: 350 TURBO BUILT BY B&M
Axle/Gears: 12 BOLT POSI
I bought my car off my aunt and she told me she bought it new in late 86 she special orderd the performance package with the 4 speed automatic
iam just asking because i herd there wer good tpi engines and there wer bad
p.s why do most of the 305 tpi parts not match my motor ???just remember the car was bought in late 86 so i dont know what motor this is please help p.s when i take off my both back wheels spin like crazy everyone tells me that my car shouldnt have a possi but iam not complaning lol iam just trying to find out what tpi i have with a 4 speed auto tranny thanks everyone please get back to me
Old May 31, 2007 | 11:34 PM
Z_wonderer's Avatar
Car: 86 z28
Engine: LB9 305 TPI
Axle/Gears: 2.73 gears
Re: what motor do I have????
chek your arm rest compartment or in the rear storage compartment and see if there is a sticker with some codes, take a picture of that and post it here, that will help us here to see what your car came with.
Old Jun 1, 2007 | 09:06 AM
online170's Avatar
Car: 1987 Firebird
Engine: 355
Behind the driver's side cylinder head, just before the bell housing on the tranny, there is a casting number. If youre flexible and good with a flash light, pop the hood, DO NOT STICK YOU HEAD UNDER THE HOOD< but if u angle is just right you should be able to see the number from outside with the hood popped. It will be grimy so u need to clean it off. OR just feel for the number.
Itll say 5.0 or 5.7. It'll atleast help you narrow down which it is, 305 or 350. Theres also stampings all over the engine that'll identify which car it when into. You will also need the cylinder head numbers to figure out how good it is.
Old Jun 1, 2007 | 09:50 AM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
If its an 86 then its a 305 if its an 87 then look at the VIN... the 8th digit is an "8" for the 350 and "f" for 305 TPI. H for LG4 4bbl...
Your VIN should read: 1G1FP21??G....
John
Old Jun 1, 2007 | 09:56 AM
Car: 87z28
Engine: 70 LT1
what motor is this???
Attached Thumbnails what motor do I have????-engine-002.jpg   what motor do I have????-engine-003.jpg   what motor do I have????-engine-006.jpg
Old Jun 1, 2007 | 10:01 AM
Car: 87z28
Engine: 70 LT1
if it is a 305 than which one?? because all the 305 tpi parts i find wont work on this my uncle said he orderd the 350 in it ???so i dont know if these numbers will match my car shouldnt have possi either right at least that is what i was told but it does ....what tranny do i have it is a 4 speed auto
he said he orderd the 87 performance upgrade late in 86 when he bought this car i dont know iam lost
Old Jun 1, 2007 | 10:53 AM
kairles's Avatar
Car: 89 IrocZ/17 LS 1LE
Engine: 383/LGX
Transmission: 400/TR-3160
Axle/Gears: 3.08/3.27
per the VIN it is the LB9 305 TPI motor. when my 86 was still a TPI I had a hard time with parts fitting also. mainly spark plug wire. make sure when you get the part you get them for the fuel injected 305 or the VIN "F" motor.
Old Jun 1, 2007 | 04:19 PM
okfoz's Avatar
You have a 1986
Your engine is the LB9 TPI (305)
Basically your stuck in the middle the block may or may not have the one piece rear main seal, your heads are the early ones with the side mounted bolts, instead of the center valve covers, your distributor is the large type, whereas the later 1987 & up used the remote coil. Otherwise its very similar to the 1987, your accessory pulleys, belts etc sould be the same as a 1987, your Heads are the same as a 1985, so the Intake is unique, IIRC a 1987+ intake will work but you have to grind out some of the holes so they line up with your bolt holes to the heads... not for the faint of heart...
Beyond that your runners, Plenum, & throttle body, are interchangable with an 85-88, 1989+ will not work because you have the 9th injector for starting, your Idle air goes through the same passage...
John
Old Jun 3, 2007 | 05:41 PM
Ashbrook's Avatar
Car: 1986 IROC
Axle/Gears: 2:73posi
Yeah, it's a 305. You have exactly what I have. Mine was an end of the model year so it seams they used some 87 parts at the factory. Your rearend is probably a 2:73 posi which isn't real good but you'll get power from your 700r4 tranny to make up for the lacking rearend. I'm getting ready to put a 3:73 posi just to pep it up a bit. Also if your planning on lighting your rubber up often invest in some frame ties.
Old Jun 3, 2007 | 08:12 PM
Iroc_man's Avatar
Car: 87 Iroc
Axle/Gears: stock posi
yeah, you probably got the pos 305, 190hp crap.
Old Jun 4, 2007 | 08:42 AM
okfoz's Avatar
The NICE thing about 1986 is you have the older style heads, so you can get yourself an old 400, install that, replace the valve covers with yours, paint it all up so it looks stock and tell everyone its a little old 305.. then do a little whoop butt on them on the track... scratch your head and say I don't know it runs better than I thought.
Old Jun 4, 2007 | 01:28 PM
Car: 87z28
Engine: 70 LT1
hmmm a idea thanks oxfoz time to put the mad sciantist to work hehe
Old Jun 8, 2007 | 04:37 PM
roachjuice's Avatar
Car: 86 Omni GLHT
Engine: 2.2 Turbo/Intercooled
Transmission: 5 speed
Axle/Gears: 3:85
305. peanut cam. runs high 15's to low 16's. rip the motor out of it rebuild it with low compression pistons then turbo the bastard!!
hydrolic144
Sep 8, 2015 06:55 PM
greenyone
Aug 29, 2015 11:08 AM
Randomtask2
Aug 26, 2015 03:34 PM
madsv1000
Aug 20, 2015 06:45 AM
slade5612
Aug 11, 2015 07:19 PM
