383 question
Old Sep 24, 2000 | 06:44 AM
kwikgta's Avatar
383 question
I recently purchased a Scat 383 stroker crank and a set of 6.0" rods to put in the GTA this winter.Here lies the problem: I went to www.scatcrankshafts.com ,I noticed that they sell 2 different cranks for the 1 piece seal motors.The first is for 5.7 rods & externally balanced(the one I bought).The second is for 6.0" rods & internally balanced.
Can I still use the 6.0" rods and just have my machinist take care of the balancing?
I have a friend who has 6.0" rods in a 400 sb with the stock crank and external balancing,so I don't know why I couldn't do the same thing unless there is some physical reason I am missing.
What do you guys think? I would hate to buy another crank or set of rods.
92 GTA(only 226 made)ort matched sportsman heads with 2.05 valves,64 cc,milled .015,.028 head gaskets,port matched Accel runners,port matched plenum,port matched edelbrock intake,flow matched injectors,jet hot headers and 2.5" mandrel bent exhaust,Flowmaster muffler,underdrive pulleys,slp cam,1.6 rockers,slp cold air induction,52mm throttlebody,performance resource custom chip,Dyna module,Screamin Demon coil,Accel 8.8 wires,Bosch platinum plugs,timing at 10 degrees,tb bypass,relocated map sensor,shift kit,Fairbanks billet servo,pump vane kit & 2400 stall,Torque converter lockup switch,3.42 posi with welded axle tubes,Zexel Torsen HD diff.,Summit rearend girdle,solid pinion spacer,& alloy axles.Boxed panhard bar,lakewood lca's & edelbrock strut tower brace,Jeg's torque arm,Jegs welded in subframe connecters.Performance friction pads,turbo slotted front rotors,stainless braid brake lines.Roh ZT 17x8.5 front wheels with 255/40ZR/17 tires. 17x9.5 rear wheels with 275/40ZR/17's on the street.Hoosier 26x9.5 slicks on the strip.
Old Sep 24, 2000 | 10:30 AM
Kevin G's Avatar
your fine. An internally balanced crank is a little more expensive, and some people do this so they can use a 350 balancer, and try and hide the fact it is a stroker motor. I actually first externally balanced my 383 motor, but I eventually put the motor in a racing bracket where strokers were...illegeal..Well, I internally balanced the motor to give it that good ol 350 look..
I would just give the machine shop your whole rotating assembly and have them balance everything as a whole. Have them size the rods and give them the flywheel, and balancer, and crank to balance it all together.
Old Sep 24, 2000 | 10:46 AM
kwikgta's Avatar
Thanks Kevin,I realy appreciate it.I'm relieved that I don't have to sell my stuff and buy more!
Would like your opinion on one other thing also.
My car has the speed density system,I had the chip custom burnt by PR to work with my heads and cam,etc.If I use the same cam & heads with the 383,do you think I can get by without having to get a new chip burnt?I only have the fuel pressure set at 42 psi & it still runs a little on the rich side.
Also I posted my rods for sale in the classifieds yesterday,can you please delete the ad.
Old Sep 24, 2000 | 12:30 PM
Kevin G's Avatar
You know what Kwikgta..........I went and looked at what you were saying about their website....and I think you need to call them up on Monday to be sure.. I used a GM crank. I know with these, different size rods will work no problem, but maybe their SCAT cranks are different. I am pretty sure you will have no problems, but call them to be sure.
Old Sep 24, 2000 | 12:33 PM
kwikgta's Avatar
You're right,no sense taking a chance!!!
Do you have any insight on my chip question?
Old Sep 26, 2000 | 05:20 PM
kwikgta's Avatar
Kevin I talked to Scat and they said that I will have to add a lot of heavy metal to the crank in order to internally balance it with 6.0" rods.I think I will just sell it and get the crank that is for an internally balanced 383 with 6.0" rods.
Cameeeero
Sep 18, 2015 04:00 PM
Mickeyruder
Sep 2, 2015 02:45 PM
gixxer92
Sep 1, 2015 04:32 PM
lt1z350
Aug 28, 2015 05:57 AM
redmaroz
Aug 16, 2015 11:40 PM
