M.A.F. sensor
Old Sep 25, 2000 | 08:46 PM
bigdaddy's Avatar
M.A.F. sensor
Can you install a map sensor in place of the stock maf sensor on a 1987 Trans Am 5.7? I want more clearance and Air flow. There use to be a way when the GM stock maf sensors were failing left and right. Anyone out there know how to do this?
Old Sep 25, 2000 | 09:32 PM
graebz28's Avatar
Car: 83 Z28
Engine: 406
Axle/Gears: 9" with 4.10s
This would require changing the computer and wiring harness.
I have the same problems w/ my MAF.
Someone on the board mentioned before a company that makes better ones that use a film instead of that crappy thin wire!! I think GMTECH knows who.
Michael Graeber
My Garage
1)83 Z-28 T-Top: Full cage, 9" w/ lad.bars, Midwest Engine Tech 406sbc,Strip Dominator, Demon Carb, Phase VI Chevy Bowtie heads, .630" Crower roller set-up, 1 3/4 coated Hookers 3" true dual exhaust th400, fuel cell & still not running
2)89 Formula WS-6 305 TPI Auto For the road: minor motor, more suspension stuff. MODS
Old Sep 25, 2000 | 11:10 PM
Stell1579's Avatar
its the Wels unit. it uses a chip and a honeycomb matrix on one end. its like 180.00 or so. i think i remember Vader giving the info on how to get it. its special order from wels i think. anyone ho knows letus know i need one too
-Stell
1988 IROC 305TPI MINT!!
Mods= Accell SuperCoil, MSD 6A, Ported Plenum, No MAF Screans , K & N, 160 Thermostat+ Temp Switch
And Always Trying To Go Faster
Old Sep 26, 2000 | 12:41 AM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Axle/Gears: Strange 12-bolt
You can get the Wells SU-145 at www.wdautoparts.com call (800)288-6728 extension 115 ask for Tom Martin
GTA -89:Free flow muffler,dual 3" HF cats, Edelbrock headers, Vette heads, 1.52 RR 7/16, ZZ-9 cam, Big Mouth, AS&M LTB, ported plenum, 52 TB, MSD 6AL, TPIS level V prom, Mod .MAF, Superior shift-kit and some minor mods. and more to come!
http://www.itv.se/tacs/members_cars/m279/m279.html (Swedish Trans Am Club)
Old Sep 27, 2000 | 02:02 PM
graebz28's Avatar
Car: 83 Z28
Engine: 406
Holy $h!T.
Are you telling me that for approx. $180 I can dump the MAF and install a MAP w/o changing the computer.
Is that all you have to buy?????
Please, let me know.
Old Sep 27, 2000 | 03:57 PM
Buck Mustard's Avatar
Excuse my ignorance, but could somebody explain the difference between MAF and MAP? TIA!
Old Sep 27, 2000 | 04:05 PM
graebz28's Avatar
Car: 83 Z28
Engine: 406
There are two differnet control systems for TPI.
85-89 uses a Mass Airflow Sensor to determine the amount of air entering the intake.
90-92 use a Speed Density system that used a Manifold Absoulute Pressure sensor to measure the amount of pressure in the intake to determine airflow.
You will see a lot of arguemnts over the 2. Facts claim that a MAF system responds better to mods.
Personally, I have had enough trouble w/ the MAF, so I would like to see it gone. Usually, this meant that you would have to change the computer and wiring harness which is a PITA and quite well out of my price range.
What I am hoping is that there is a way to do this with the kit mentioned above and not having to change the ECM.
So can anyone expand on this and let me know???????
Old Sep 27, 2000 | 04:34 PM
Guest
Guest
Posts: n/a
Its not a kit, its a replacement MAF that uses a different method for measuring the air. If you want to go to a MAP sensor, then you will have to do some wiring changes and swap computers.
Old Sep 27, 2000 | 04:42 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Originally posted by graebz28:
Holy $h!T.
No, the Wells unit is a replacement MAF sensor that is supposed to be better than the stock GM unit, and cheaper too.
To switch to a MAP setup, you need the computer, wiring harness, and MAP sensor, along with the correct intake plumbing.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
Old Sep 28, 2000 | 12:25 AM
graebz28's Avatar
Car: 83 Z28
Engine: 406
Thank you!!
It was confusing since the orginal question asked:
Can you install a map sensor in place of the stock maf sensor on a 1989 Trans Am 5.7? I want more clearance and Air flow.
I'd rather say with MAF, just realize that the wire filament MAF just don't cut it.
Are these the ones I have heard mentioned before that use a film rather that a wire filament??
Regardless, sounds like a great mod.
They flow the same cfm or better, right?
HoosierinWA
Oct 7, 2015 10:15 AM
aaron7
Sep 30, 2015 09:15 AM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
dusterbd
Sep 29, 2015 08:40 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
