Little problem...surging
Old Jun 4, 2007 | 08:47 PM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
well, before I replaced the oil pan, the car would surge and stall untill it was warmed up, so I would warm it up for a minute and it would be fine. After replacing the oil pan (had an oil leak and oil pan was messed up) with the same one, just new, It doesn't want to idle at all. It is fine driving, but if it idles, it will surge bue not stall, it will go from around 200 rpm to about 900 rpm. when driving it will surge if I cruise at 1200 rpm. What is this problem. Oil is fine, coolant is fine.
Old Jun 5, 2007 | 02:37 PM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
Re: Little problem...surging
Need help asap!
Old Jun 5, 2007 | 02:50 PM
joejoe's Avatar
Car: red one
Engine: on the floor
Transmission: next to engine
Axle/Gears: the ones that turn
Sounds like a IAC, do a search on it to see how to clean it, also check the TPS
Old Jun 5, 2007 | 10:23 PM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
both IAC and TPS are new. Not many miles on them. I think it may be a vacuum leak. Any other suggestions?
Old Jun 5, 2007 | 10:58 PM
Sprayed92's Avatar
Car: 92 Formula
Engine: 383 248/256 cam
Transmission: 700r4 3500 stall
Axle/Gears: 9" 3.89 gears detroit locker
Your Iac and tps are both new but is the tps adjusted right?
Old Jun 6, 2007 | 12:18 AM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
No idea. I will check. How hard are they to adjust and what should I adjust them to?
Old Jun 6, 2007 | 12:23 AM
TPI's Avatar
Car: '89 Trans AM/'88 GTA
Engine: (2) Tuned Port L98's
We have a article here:
https://www.thirdgen.org/tpimod2
Old Jun 6, 2007 | 12:29 AM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
Ok, Thank you. I will check up on it tomarrow.
What should my idle be at with my mods? Around 700 RPM?
Old Jun 6, 2007 | 12:50 AM
TPI's Avatar
Id say 650-700 should be ok.
Depends.. if your a stickler on fuel consumption
Oh yea, did you ever get that Y-pipe off the oil pan?
Old Jun 6, 2007 | 09:06 AM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
I actually had a hard time putting it on. I got it on, but it is hitting the oil pan, so I think I am going to put some high heat cloth to help with the vibrations and heat.
Old Jun 7, 2007 | 03:39 PM
joejoe's Avatar
Car: red one
knowing this it may be the knock sensor pulling timeing because of the Y/pipe rattleing on the oil pan, that is the same problem I am dealing with right now.
Check mt post.....for the gear heads....
Old Jun 8, 2007 | 12:39 AM
TPI's Avatar
Originally Posted by joejoe
knowing this it may be the knock sensor pulling timeing because of the Y/pipe rattleing on the oil pan, that is the same problem I am dealing with right now.Check my post.....for the gear heads....
Yea, that was the direction my question was going
when I asked if he had any luck with the Y-pipe.
That could be the issue, maybe.. throw any codes?
