engine sputtering..running rich?
Old Oct 14, 2000 | 09:07 PM
theformula's Avatar
ON my way home from Ocean City,MD today I was cruising and i stepped on it in 5th gear. Well the RPMS did not move! It felt like they were being redlined or something. They rose very very slowly.
I recently made cold air induction, ported the plenum, and installed an AFPR. I'm running about 49psi at WOT. Why would the car sputter like that? Am I running rich? I can hear the sputtering in lower gears too..just not as drastic. Other people in the car have noticed it. Maybe my injectors are getting too much fuel?
thanks guys.
'92 Formula
305 TPI
Mods: SLP catback,SLP air foil,ported plenum,Crane AFPR (49psi),MSD6AL,homemade cold air,K&Ns,3:73s
[This message has been edited by theformula (edited October 14, 2000).]
Old Oct 15, 2000 | 10:29 AM
Blade's Avatar
Try to lower your PSI a little ? That seems a little high...
92 Z28 L98 350
Ported and polished heads, ported stock TPI base, ported plenum, Comp Cams XR270HR-10 cam (lift .495/.502 duration 218/224 lobe separation 110), Edelbrock TES headers, LT4 valve springs, Crane AFPR, Flowmaster catback with LT1 style tips, MSD coil & wires...
"Take that auto, drop it in first, hold the brakes, stomp the gas and grin from ear to ear! :-)
Old Oct 15, 2000 | 04:16 PM
rondubbs's Avatar
49 psi on a pretty much stock 305 is overkill. i wouldnt of even got a afpr for a 305.
Old Oct 15, 2000 | 05:30 PM
theformula's Avatar
If you are running lean ,you are running lean! Regardless of displacement. Once i get my dash mounted digital air/fuel ratio moniter, and digital fuel pressure gauge I will be set to go.
'92 Formula
305 TPI
Azrael91966669
25
Jun 20, 2017 04:04 AM
Zeek1041
Theoretical and Street Racing
Aug 21, 2015 08:45 PM
Winchester1094
Aug 18, 2015 10:23 AM
tmellott89
Aug 16, 2015 02:58 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
