cam or 1.6:1 rockers for mild modded 350tpi
Old Oct 19, 2000 | 11:30 AM
Superblue87Formula's Avatar
should I put a cam in my car? I already have the intake off for porting. Here are my mods and planned mods:
done: headers, exhaust cut-out
in works: intake porting, cold air, afpr
planned for later: torque converter, possibly nitrous
I don't understand cams all that well so if you all could just tell me some specific cams that would be good for me. My car is pretty much a weekend warrior, it sits in the garage most of the time..
1987 Formula 350, headman hedders, Accel supercoil, cap, rotor.
MAF screens removed. 160 degree stat and manual fan switch.
Best ET: 14.745@91.317mph-Stock
Best ET: 14.418@95.51 mph-Modded
Ridiculed Founder of the Traction Impaired Crew
Old Oct 19, 2000 | 03:42 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
go with the 1.6 roller rockers. With that your ported intake, a chip and your afpr You'll be in the 13's
89 FORMULA 350 Edelbrock Cat-Back March Pulleys
Accel Cap ,Super Coil SLP Airfoil K&N Filter 180 stat , Fan Switch
Taylor 8mm Spiral Pro,TB Bypass ,Energy Sus bushings ,Hotchkis STB ,MSD 6AL ,Edelbrock TES's ,Hi Flo Cat ,Crane AFPR ,Shiftkit w/Hurst lockup ,1/4 time 14.2@98
Old Oct 19, 2000 | 09:13 PM
Dan87IROC-Z's Avatar
No way, go with the cam. You can get an LT4 hot cam for like $190, thats what rockers will cost you and the cam will get you SO much more.
1987 Chevy Camaro IROC-Z
L98 TPI 350 (5.7L)
TH 700R-4 Transmission with 2.77:1 Rear End
Current Mods: Edelbrock TES 1 5/8" Headers, Hooker Aerochamber Cat-Back System, Performance Resource Chip with 160* Thermostat, Accel Ignition Components, K&N Filters, All Free Mods, Falken ZIEX Z-Rated Tires.
Best ET : 14.32 @ 97.7mph
(corrected for elevation)
Old Oct 19, 2000 | 10:10 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Yes the cam is the way to go, but if you dont know how to install it or if your pressed for time go with the 1.6. I know the LT4 works with higher rpm so make sure your intake can take it.
Old Oct 19, 2000 | 11:27 PM
airdeano's Avatar
umm besides the 'porting' you have a stock engine, yes? stock heads, valves, and throttle body? if you feel a cam change is needed keep the duration under 214deg @ .050.
anymore that that itll waste. the lt4 hot cam is a fine cam, but $$$ will be needed to replace and prep heads and compression is needed. ohh and the tpi will work but the streetram or superram would be the better manifolds if your wanting the L-98 look. other than that miniram would be best. cam profile is 2500-6500rpm. on stock tpi 1500-5000rpm is more desirable.
airdeano
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
haps
Interior Parts Wanted
Sep 8, 2015 10:15 AM
masonta
Sep 1, 2015 06:40 PM
SLNTSCPE
Aug 22, 2015 09:15 PM
