battery/alt issues
Old Jun 19, 2007 | 06:58 PM
Teds92RS's Avatar
Car: 1989 Camaro IROC-Z
Engine: Lt1
Axle/Gears: Quick performance 9" 4.11
battery/alt issues
Hey guys, long story short I replaced my main cable going from the battery to the starter a while ago and I had to get rid of the fusable links hooking up to the battery +. I ran the red wire directly to the battery, added an inline fuse with a 30a fuse to the orange wire and then to the battery. The orange wire gets extremely hot and melts the fuse while running. At night with all my lights on, turn signal and brake applied my volts are in the red and the car almost stalls. I already tried a new alternator and I have the same problems. I've been checking out wiring diagrams and doing countless searches and I can't find any answers, any help is greatly appreciated. Here are some pictures of what I'm working with:
Old Jun 19, 2007 | 08:31 PM
1fastam's Avatar
Car: 1991 transam
Engine: 305 30 over long tubes into 3" y
Axle/Gears: 4:10
Re: battery/alt issues
try running a ground wire from the - post on battery to the engine block ,sounds like your ground isnt real great hope this fixes it ,later jimmy
Old Jun 20, 2007 | 08:24 AM
Vader's Avatar
And install about a 40A MAXI fuse in the line for the accessory power (orange wire), or install a fusible link again.
gta892000
Aug 11, 2019 11:16 AM
MM2Robinson
Oct 1, 2017 09:16 AM
nova983
European Region
Nov 2, 2015 12:15 PM
TheTraut88
Sep 11, 2015 05:16 AM
Fronzizzle
Sep 8, 2015 12:10 PM
