What are the differences from different year TPI setups?
Old Oct 26, 2000 | 08:35 AM
Dana92RS's Avatar
If I understand it correctly, the manifold bases differred from 85-86 and 87-92 with the later years having the center manifold bolt angled for the 87-later heads.
The runners were 85-88 (w/ cold start injector hole) and 89-92 (w/o cold start injector hole).
The plenums were 85-88 (w/ cold start passage), 89 (w/o cold start passage), and 90-92 (w/o cold start passage & w/ MAP boss).
What about the throttle bodies? From what I can find there was a difference between the 85-88 and the 89-92 TB's but I don't know what those differences were.
Am I correct on my descriptions? Any other info would be appreciated. Thanks.
[This message has been edited by Dana92RS (edited October 26, 2000).]
Old Oct 26, 2000 | 02:24 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
You're correct on the plenum/runners/base. The TB difference is the way the IAC passage routes, and the way the throttle cable connects.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
customblackbird
Aug 15, 2021 10:16 PM
onefreakz
May 14, 2018 12:15 PM
Street Lethal
Aug 13, 2015 08:28 PM
Sanjay
Aug 12, 2015 03:41 PM
squiggy2
Aug 9, 2015 09:30 PM
