maf/map tpi
Old Oct 23, 2000 | 07:44 AM
ausrs's Avatar
maf/map tpi
ok i have a 1991 with vats tpi
i also have a 1986 vette tpi complete with the maf sensor ..so i am told that maf is better than map ..wont argue with that coz i dont know .what i need to know from someone who has already done a tbi to maf tpi is does everything except the passkey system work ????? speedo ,tacho etcetcetc ...not much point in doing a street car with no speedo that works ..someone must have done this conversion and have a few answers for me to use
thanks
steve
Old Oct 23, 2000 | 07:55 AM
Aaron's 87's Avatar
MAF measures actual airflow, MAP calculates airflow. 80s GM MAFs read to 255 grams/sec - not that much. After that point, the computer adds fuel based on RPM and TPS. MAFs cost a lot of money. High performance guys switch to MAP from MAF because of the 255 g/s thing. There is a page on switching from MAF to MAP - I can dig it up if you'd like.
Old Oct 23, 2000 | 08:02 AM
ausrs's Avatar
...the fact that it is maf not map doesnt bother me at all ..i havent started the conversion yet ..just if i go map i will need an ecm .....i still need to get a harness whether i go map or maf so isnt that big a deal my main concern is for the accessories like tha speedo etc ..i want to know that they will work with the conversion ...i can prob sell the maf (brand new) to cover the cost of the ecm again so it isnt a problem ..someone must have done this before !!!
Old Oct 24, 2000 | 06:16 AM
ausrs's Avatar
Old Oct 24, 2000 | 02:28 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
You have a 91 car, use the 91 speed density system. Or use the 89 MAF system. Those would be the two best choices. Whichever one you choose depends on which one you get first, for the best price.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
Old Oct 25, 2000 | 02:33 AM
ausrs's Avatar
this is australia
the only tpi that i could get was from a 1986 corvette ..i have the ecm maf etc just have to get the harness sent over .i have what i have and will use it i just need some simple answers to the accessorry question
Old Oct 25, 2000 | 03:09 PM
Kevin91Z's Avatar
Ok then, yes it should work. I dont now when the Corvettes went to electronic speedos, but the Firebirds did in 87, and they still used the same 7165 computer that the Camaros did, but with cable speedos till 89.
Old Oct 26, 2000 | 12:04 AM
ProblemChild's Avatar
MAF will support more hotrodding without custom chips, that I do know, as far as the rest I'm not sure, I know both computers require the same signals, the vss can be done with an adapter. I believe the corvette uses dual o2's though. Give me more details and i can figure it out.
P.C.
Torque is KING!
All pray to the god of grunt! When ye thinkth ye has been whupped than shall ye meet the mighty Buick! For none can surpass her majestic power, and all will yet try. All pray to the god of grunt. For the King of torque has arrived!
1. 82 Camaro+ 1. 455" Buick+ 1. N2O plate = YOUR WORST FRIGGIN NIGHTMARE!!!
Da Problem Child
ProbChldR@aol.com
Old Oct 26, 2000 | 12:45 AM
ausrs's Avatar
thanks problemchild
this is an 86 vette and i believe that it only has one o2 sensor ..the adapter for the vss sounds good though
this setup wont be going in till the motor is built and all associated stuff is obtained because i will not be able to get anything from the junk yard ..
Old Oct 30, 2000 | 11:37 AM
-=Jeff=-'s Avatar
Car: 1990 Corvette ZR-1
Engine: LT5
Transmission: ZF6
Corvette's did not go to dual O2s until somewhere in the 90's...
My 89 has one O2 and is a MAF set-up
-=Jeff=-
89 Corvette Coupe White with Black Grand Sport Stripe
Check out my mods on My '89 Vette
Old Oct 30, 2000 | 12:01 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Hey ausrs...
You may want to look into Holley's ECU setup...it has the ecu (programmable), SD wiring harness that eliminates the MAF, does not use the VAT's. VSS may be an issue, but email Holley for details...price seems right at about 750/800 USD.
The reason I mention this is after 250 for a harness, another 250 for a prom, and hoping it'll be what you want on the first shot....the price gets pretty close to the Holley setup.
[This message has been edited by 8Mike9 (edited October 30, 2000).]
stalkier
Dec 6, 2015 11:25 PM
ChaseDale3and8
Sep 1, 2015 01:49 PM
Keith5
Aug 27, 2015 04:37 PM
theurge
Aug 21, 2015 12:46 PM
Sanjay
Aug 12, 2015 03:41 PM
