TPI on an LTI engine?
Old Oct 27, 2000 | 04:25 AM
PerthZ28's Avatar
Will the stock TPI manifold bolt up to a Gen2 [LT1] motor?
Old Oct 27, 2000 | 01:42 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Nope. Everything's different.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
Old Oct 27, 2000 | 07:50 PM
DownUnderIROC's Avatar
Isn't someone building a new TPI base that will allow this to be done?
1987 Chevy Camaro IROC-Z
1998 Ford Falcon XR8
My IROC-Z in Sydney, Australia.
Thunder Down Under home page.
Old Oct 29, 2000 | 10:22 AM
Markolc's Avatar
Car: '87 IROC
Engine: LT1 350
Transmission: 700-R4
I don't understand why you'd want TPI on an LT1? The LT1 intake is already a very good intake, in fact it rivals a miniram with a little porting. Maybe if you want a bit more torque you can use the TPI but then you'd lose HP in the 4500-6000 RPM, and that's where the LT1 is known to shine.
Old Oct 29, 2000 | 01:08 PM
IrocManiac's Avatar
Are you speaking of the 1970's LT1??? I think it was like 70 or 71 because you did say Second Gen.
TPI 305,
Gutted airboxes,
gutted MAF,
K&N filters,
Corvette Servo.
14.9@93mph
"Speed kills, wanna live forever, drive a Ford."
Old Oct 29, 2000 | 04:43 PM
Blade's Avatar
Gen2 SBC.... The LT1, NOT the LT-1.
Old Oct 29, 2000 | 06:57 PM
MikeH's Avatar
Car: 90 IROC
Engine: 406
Transmission: GMPP 93/4L60
Axle/Gears: 9 bolt 3.27
Lingenfelter has a SuperRam for the LT1 4th gen cars. The guy I bought my SuperRam from was replacing his LT1 intake for the SuperRam to increase torque.
Black 90 IROC, L98, A4, 323 gear. SuperRamed 406 in the works!
Old Oct 29, 2000 | 07:15 PM
Tas's Avatar
Tas
most common thing to do to get back the torque of an L98 on an LT1 is to just make it a 383.
Old Oct 29, 2000 | 07:37 PM
PerthZ28's Avatar
I know it's kind of a weird question but there is a guy here in Australia who sells LT1 crate motors equipped with carbs and HEI distributors. I have a TPI set-up I was going to put on my motor but the brand-new alloy headed roller LT1 he sells sounded pretty good!
Old Oct 30, 2000 | 01:33 PM
Tas's Avatar
Tas
oh if thats the case then maybe you can get the motor, buy an LT1 intake from www.camaroz28.com or ebay for $100 and try to get your computer to run it.
Old Oct 30, 2000 | 03:20 PM
RCR's Avatar
RCR
Car: '84 Fiero ('01 GA interior)
Engine: '96 4.0 Aurora
Transmission: '96 4T80E
GM sells (or sold) LT1 crate engines with a carb manifold and distributor. The problem with putting the LT1 intake back on is that the distributor no longer fits (no hole). You'd also have to switch to the Opti-spark setup. If this guy sells LT1 crates, he might have a ZZ4 for you.
Bob
Old Oct 30, 2000 | 04:09 PM
Kevin91Z's Avatar
GM sells an LT4 crate engine with a carb on it.
Vintageracer
Jan 10, 2020 05:33 PM
Caspar
Jun 19, 2016 11:19 PM
R3500
Aug 17, 2015 12:16 PM
Sanjay
Aug 12, 2015 03:41 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
