Porting the Plenum?????
Car: 1988 Trans Am GTA
Engine: 383
Need a few questions answered......
What drill bits will I need to properly port the inside of the plenum??
What grade sand paper is best to polish the plenum??
Can you port the TB, and if so will I need to get bigger TB plates??
Any help is appreciated.
88 GTA
L98 350
700R4
3:27 axle
MODS,
Edelbrock TES headers, 3" straight pipe, Flowmaster 80 series, K&N filter, Accel 8.8mm wires, Bosch Platinum plugs, Wells cap and rotor button, Wells ignition module, MAF screens removed, Hypertech TB air foil, Thermomaster stage II chip, 180* Powerstat, Hypertech cool fan switch, B&M shift kit, B&M power clutch pack, B&M servo, GM fuel filter.
88 GTA
L98 350
700R4
3:27 axle
MODS,
Car: 89RSconvtZZ4TPI
Engine: ZZ4TPI
Transmission: 700R4 TRIPP TRANNY
First, don't do anything to the Tb unless you're an expert! That's best left to the experts.
Hit the dremel bits stand in your hardware store and get the barrel sander with 60 to 150 grit rolls. Thats what I used. You could go rougher, like 40 probably to move more material quicker. For the major areas I got the cutter that looks almost like a gear, it's silver, shiny and only cuts in one direction, sorry, don't have the pkg anymore. Hope this helps.
Rob P
89RSconvtZZ4TPI
92Z28convt5spd
71Impala convt 402BB
BETTER DRIVING THRU SUPERIOR HORSEPOWER!
Rob P
89RSconvtZZ4TPI
92Z28convt5spd
Engine: 355 TPI
Go here...it'll tell you what you need to know: www.tribal-treasures.com/...t/port.htm
--Aaron
'89 Trans Am GTA 5.7
--Aaron
Engine: 355 TPI
Oops, try this *LOL*: http://www.tribal-treasures.com/cars...-port/port.htm
--Aaron
--Aaron
Car: '76 Camaro, '94 Z28, '94 Corvette, '03 Mustang GT
I would use a die grinder, not a Dremel. The Dremel is small and won't have the horsepower you need, not to mention the reach inside the plenum. A die grinder is more expensive though.
instead of wasting yer time with this TPI i would spend the time and money on a good intake and carb...TPI is ok if you got ALOT of money to spend ....and don't mind CONSTANT problems.Oh yeah and when you have a problem ...good luck finding a good wrench to really find the problem
87GTA,350,Auto,MAF screens removed,195 thermostat,cold start injector UNPLUGED,K&N,modified air intake,ADSchip,3:70s,3inch cat back Flowmaster single outlet,TPS.54,Bosch Plat plugs,base timing 6BTDC,22 MPG,what a ROACH,Bilstiens in the rear....,don't let yer meat loaf
A Dremel is plenty adequate when it comes to porting the soft metal of the plenum and intake manifold. Works very well. You can also buy a flexible attachment that allows you to go anywhere a die grinder could go.
I found that my local welding supply had bulk abrasive cartridge rolls & mandrel bits way cheaper than the porting "kits" like the Standard Abrasives ones in Summit or Jegs. I spent maybe $15 for enough to port the plenum, runners, and base. Also a carbide aluminum (course) burr is really helpful for removing the thick parts, then polish with the abrasive rolls.
I think that a 1/4" collet die grinder is the way to go; if you have an air compressor a $20 "cheepie" from harbor freight (etc..) will outperform a dremel by quite a bit (was that a pun?
A drill will work too but it sure would be awkward to say the least.
Good Luck,
-Tim-
A drill will work too but it sure would be awkward to say the least.Good Luck,
-Tim-
Car: 83 Z28
Engine: 406
Axle/Gears: 9" with 4.10s
Michael Graeber
My Garage
1)83 Z-28 T-Top: Full cage, 9" w/ lad.bars, Midwest Engine Tech 406sbc,Strip Dominator, Demon Carb, Phase VI Chevy Bowtie heads, .630" Crower roller set-up, 1 3/4 coated Hookers 3" true dual exhaust th400, fuel cell & still not running
2)89 Formula WS-6 305 TPI Auto For the road: minor motor, more suspension stuff. MODS
