code 43 knock sensor
Old Jul 1, 2007 | 02:39 PM
Pocket's Avatar
Car: 91 Trans Am
I tripped a code 43 in the 91 GTA 5.7 TPI
New knock sensors installed
New pigtail installed (old was fried)
Still get the code after clearing
Haynes manual says the knock sensor gets a continuous 8-10 volt current
Running test got a range of .15-.3 on the multimeter
Haynes also suggests a possible defective ESC module
I cant find any such module in the engine bay nor a 4 pin plug dangling about
My 92 TBI has the module in place on the firewall where it should be
Any ideers?
Old Jul 1, 2007 | 03:13 PM
DENN_SHAH's Avatar
Car: 83 POS monte carlo 2015 chevy P/U
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
Re: code 43 knock sensor
the Haynes manual is wrong on the voltage to the knock sensor, it gets 5 volts.
on your 91 5.7 TPI, there isn't a ESC module under the hood, its part of the ECM.
unplug the knock sensor & with the key on engine off, check the voltage at the knock sensor connector, any thing other than 4~6 volts is a problem.
if the voltage checks good, with the sensor still unplugged check the resistance of the knock sensor, go from the center contact of the knock sensor to the engine block, it should be around 3.9k ohms, specs call for between 3300~4500 ohms.
Old Jul 9, 2007 | 07:02 PM
Pocket's Avatar
Car: 91 Trans Am
I have 12.2v at the wire and 4,300 ohms sensor with ign to run, car is not running like previous test
Yeah theres the problem
Any ideas?
Old Jul 9, 2007 | 08:28 PM
JulieGTA's Avatar
Car: 1991 GTA
Engine: 350 tPI
Axle/Gears: 342
I kept getting a code 43, voltage and everything checked out, all the wires and plugs were good.
Even swapped out a different ECM (computer) and the chip, and the code still popped up! (Thats something to try, if you have another 3rd gen handy.)
We finally found that there wasn't good contact in the sensor plug end. (The prongs?)
edit: oh, I see you're getting something different with the voltage
Old Jul 9, 2007 | 08:59 PM
Pocket's Avatar
Car: 91 Trans Am
I disconnected the ECM and retested
Still got a 12V
Im pretty sure i have a short
Old Jul 10, 2007 | 03:17 AM
DENN_SHAH's Avatar
make sure you have the right connector, the cooling fan switch is in the head right above the knock sensor & both connectors are the same. the knock sensor wire should be dark blue, the fan switch shows to be a black wire, although i have seen some that are gray.
the cooling fan switch wire would show around 12 volts key on.
Old Jul 10, 2007 | 09:00 PM
Pocket's Avatar
Car: 91 Trans Am
Actually that was the problem
Ive only had this car a few weeks and never would have thought the last owner would screw THAT up
Old Jul 10, 2007 | 09:40 PM
DENN_SHAH's Avatar
sure thing
BumpaD82
Feb 26, 2016 02:57 PM
FormulasOnly
Sep 10, 2015 09:07 PM
MSgt Luttrell
Sep 5, 2015 11:28 AM
tgp1990
Sep 4, 2015 06:24 AM
