how to check injectors
Old Jul 10, 2007 | 11:28 PM
kowboy59's Avatar
Car: 88 iroc-z z-28
Engine: 383
Transmission: th400
Is there some way or is there something to look for to see if they are bad. I have it all taken out and dont wanna do it again. lol its such a pain and I'm not looking foward to putting it all back then .finding a bad injector
Old Jul 10, 2007 | 11:41 PM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
Re: how to check injectors
First do a search and u will find all of these answers.
Ohm the injectors, factory type should be 16-17ohm range.
Lower than 12 is junk per GM. Should all be in a close range, like compression testing.
Pull the rail and pressurize it while blocking the return line to the tank, if it holds and no injectors drip, u know the fuel pump check valve is good and the injectors arent stuck open.
Also they make injector testers where u pressurize the fuel system and u [plug the tester into the injector and hold it for say 30 sec and compare all the pressure drops between injectors.
later
Jeremy
jklein337
Sep 19, 2018 06:23 PM
Red iroc-z 305
Sep 30, 2015 05:22 PM
mike_c
Aug 27, 2015 04:32 PM
Brcharrelson
Aug 26, 2015 07:47 PM
justin57
Aug 20, 2015 07:05 PM
