Comp Cam 08-304-08 and 08-305-08
Old Nov 9, 2000 | 09:04 PM
theformula's Avatar
I'm looking for these cams. Does summit sell them? If so what part number?
'92 Formula
305 TPI
Mods: SLP headers,SLP catback,SLP air foil,ported plenum,Crane AFPR (50psi),MSD6AL,homemade cold air,K&Ns,3:73s,JET fan switch, Macewen white face gauges...ZZ9 cam is coming!
Old Nov 9, 2000 | 09:19 PM
theformula's Avatar
Here are the specs, which one should I get?
COMPETITION CAMS CAMSHAFT SPECIFICATION SHEET
PART # 08-304-8
GRIND NUMBER: CS 266H-R14
ENGINE: CHEVY SM BLK 305-350
INTAKE EXHAUST
VALVE ADJUSTMENT HYD HYD
GROSS VALVE LIFT .500 .510
.006 TAPPET LIFT 266 276
VALVE TIMING OPEN CLOSE
AT .050 INT 5-BTDC 35 ABDC
EXH 48 BBDC 8-ATDC
THESE SPECS ARE FOR CAM INSTALLED
AT 110 INTAKE CENTER LINE
INTAKE EXHAUST
DURATION AT .050 210 220
LOBE LIFT .3330 .3400
LOBE SEPARATION 114
THIS CAM SHOULD USE SPRING # 986-16
PART # 08-305-8
GRIND NUMBER: CS 276H-R14
INTAKE EXHAUST
GROSS VALVE LIFT .510 .510
.006 TAPPET LIFT 276 290
AT .050 INT 0 BTDC 40 ABDC
EXH 53 BBDC 3-ATDC
INTAKE EXHAUST
DURATION AT .050 220 230
LOBE LIFT .3400 .3400
LOBE SEPARATION 114
'92 Formula
305 TPI
Old Nov 9, 2000 | 11:43 PM
ScreaminDeamin85Z's Avatar
what are you doing about a chip? you will need a chip(not really mine "runs" with 305 chip but i know i need 350 chip atleast). being a 305 and the mods you have i would choose the 08-304-8, because it has OK dur. and good lift, cant remember what the stock springs will hold but i would plan on changing them too.any more ?'s .
Brandon
"ScreaminDeamin 360"
350 60 over, TRW forged 9.83:1 pistons, crane cam 216/228 .484/.512, crane 1.6 RR's, ported plenum, home made ram air, 19 lb SVO injectors, crane AFPR
Old Nov 10, 2000 | 04:30 AM
theformula's Avatar
I'm getting a custom one burnt. By who I don't know yet. But it aint going to be TPIS for $500! hah. $500 for a $2 chip.Isn't there some law against smoking crack in the workplace?
Anyway, so you think 08-305-08 would be too big?Im going to replace the intake manifold down the road.
'92 Formula
305 TPI
Old Nov 10, 2000 | 07:09 AM
Daz's Avatar
Daz
Car: 87 Camaro
Engine: Chevy V8
Transmission: auto
I bought my 08-305-08 from Summit..I just told them this part number.
Daz
Old Nov 10, 2000 | 07:19 AM
RCR's Avatar
RCR
Car: '84 Fiero ('01 GA interior)
Engine: '96 4.0 Aurora
Transmission: '96 4T80E
From what I've researched, a 200* to 210* duration @ .050" would probably be best for a 305. That should put you at 5000 to 5500 RPM peak. Then of course you will have to make sure the intake system can support that. If it will support more, bump the duration up 10* for every 500RPM. That's why I thought the LT4 hot cam would be too much for you. Peak power would be around 6500 to 7000.
Good luck,
Bob
Bob '89 Formula CC350
Last(lost)Member of the Elusive Great Lakes Crew
My car's homepage
Old Nov 10, 2000 | 10:32 AM
the reason i suggested the 08-304-8 is because when i had my 305 i put a larger cam(Comp Cams 216/218 .444/.444 or something like that)in it and i made a big difference, and perfrmed in the same power band as the TPI system.you probably wont need a custom chip for this cam but get something like a JEt or hyperjunk(whatever makes you happy)
. what intake are you planning on buying?IMO i would not spend too much money on a 305, i would save money to build a 350 or a 400 . i have done the 305 thing and i didnt feel that it was worth it compared to the little extra money i spent on my new engine.
Brandon
F.I. 57 Belair
Aug 23, 2021 01:09 AM
Jorlain
Oct 8, 2015 01:57 AM
customblackbird
Oct 1, 2015 04:30 PM
sandman92084
Sep 12, 2015 10:27 PM
masonta
Sep 1, 2015 06:40 PM
