Bjankuski, you ran what??
Old Nov 6, 2000 | 09:24 AM
Yarnboy's Avatar
Did I read your time slip right?? You ran high 13's in your 305 with what mods?? What gears do you have?? I am not flameing AT ALL..you are getting my hopes up..heh
-Red '88 IROC 5 Speed 305 TPI w/3.08
-Dual Friction Centerforce Clutch
-Accel 300+ Racing Ignition
-Accel 300+ Pro Sleeve Plug Wires
-Accel U-Grove Plugs
-Flowmaster Force II 3 Chamber Cat Back Exhaust
-Hypertech Chip
-Hypertech Airfoil
-Removed, Then Re-installed (out of fear) MAF Screens
-Gutted Air Box
-Best E/T 14.90, 60 ft. 2.17, 1/8th mile 9.61(bald tires, Code's 34,36)
-Best MPH 92.7(bald tires)
Old Nov 6, 2000 | 09:39 AM
Yarnboy's Avatar
oh..hmm 3.45..is there any other hidden things you are doing to be a second faster than me?
-Hypertech Chip
-Hypertech Airfoil
-Gutted Air Box
Old Nov 8, 2000 | 09:11 PM
bjankuski's Avatar
Car: 1988 Firbird
Engine: 406
Axle/Gears: 4.10
The only mod not listed in my sig is the plenium porting to remove the protrusions behind the throttle body.
The car also has 101,000 miles on the orginal none freshened engine.
1988 Formula 5L/5sp 3.45 gears, SLP cold air kit, MAS gutted, TPIS air foil, TPIS AFPR, MAC headers, Mac under drive pulleys, MAC cat back, Relocated MAT.
Best ET street tires 13.85
Best 60 FT street tires 1.930
Best MPH street tires 99.29
[This message has been edited by bjankuski (edited November 08, 2000).]
Old Nov 9, 2000 | 08:37 AM
Yarnboy's Avatar
What do you attribute your second diference in times we have to?? If I port the plenum and go from 3.08 to 3.42 I'll gain 1.1 seconds?? Are these g-tech runs or track runs..
-Hypertech Chip
-Hypertech Airfoil
-Gutted Air Box
Old Nov 9, 2000 | 09:03 AM
JJ's Avatar
JJ
you have an iroc, they are often heavier than the formula. the iroc has no "real" mods listed (except catback), the formula has headers, pulley, coldair at least. I don't see that he was throwing codes . . . and, just maybe, he is a better driver
Old Nov 9, 2000 | 09:52 AM
Yarnboy's Avatar
In another post he said he gained a half second with the headers..he said he was running 14.88 before them..I don't think I am a worse driver running a 14.90 on bald tires with 3.08's apposed to his 3.42's.
-Hypertech Chip
-Hypertech Airfoil
-Gutted Air Box
Old Nov 9, 2000 | 10:21 PM
JJ's Avatar
JJ
ahh, you know all cars are different - maybe your car was built during a period when the union was mad at management . . . also, no one on this board is a "worse" driver, just ask them and they will tell you !! Seriously though, with the problems you list (tires and codes), you are running well.
Old Nov 9, 2000 | 11:05 PM
bjankuski's Avatar
Car: 1988 Firbird
Engine: 406
Axle/Gears: 4.10
Yarnboy, the times listed are actual timed runs at the drag strip. On the G-tech the car runs 13.60's at 103 MPH. The G-tech seems to read about .2 to .3 second fast when compared to my actual timed runs at the strip.
Old Nov 10, 2000 | 01:34 AM
BadSS's Avatar
A friend bought a new 305 TPI 5 speed back in either 88 or 89. Best I remember (long time ago),,, show room stock (street tires and all)it ran a 14.80 something (via my Vericom - me in the car). We installed a 160 stat, K&N filters and just took out the air deflectors, bumped the TPS and the timing, bolted on 26x8.5 slicks, took it to the track, slid the clutch at 4500,, rode it hard,,,, and I know it ran one 13.98,,, and a couple 14.0's!!! - before the stock clutch started a vacation. No one believed it was a 305,, and surely didn't believe it was "stock". I don't know for sure what gears the car had,,, but I do remember he ordered the car with the steapest gears available. Anyway,, just thought I'd throw what little I know about what a 305TPI 5 speed can do.
Old Nov 10, 2000 | 12:03 PM
Yarnboy's Avatar
This was never a flame..I want it to be true very much so! If I can gain a half second with headers I think I know where my money is going..I know the 305 TPI 5 speed can be fast..I just have to figure out how to make it go fast..thanks alot..I am once again inspired to spend money..heh
-Hypertech Chip
-Hypertech Airfoil
-Gutted Air Box
Old Nov 10, 2000 | 05:42 PM
JJ's Avatar
JJ
I wasn't ******* you . . . I have an 87 IROC that used to be a G92 car (305tpi/5 speed) w/3.45 rear. I spent quite a bit of money on it but never took it to the track. However, I could easily run with most LT1s and beat some of them, especially the early auto cars.
You have a good start, do full exhaust (headers to tailpipe, homemade "ram" air deal, then decide what to do after that (i.e. more expensive) - you cannot overlook the heads/cam/intake if your serious. in short, all cars can be made to run if you have the cash.
RedLeader289
May 28, 2019 01:47 PM
Rocket-Doc
Nov 14, 2015 02:08 PM
darwinprice
17
Oct 11, 2015 11:51 PM
Thornburg
Aftermarket Product Review
Oct 6, 2015 12:04 PM
Linson
Oct 1, 2015 09:50 PM
