LT4 hotcam, whats needed for installation in a 305 TPI?
i want to put an LT4 hotcam in my car (check my mods). What will be needed. Can I use my stock rockers and valve sprigns?
thanks guys.
'92 Formula
305 TPI
Mods: SLP headers,SLP catback,SLP air foil,ported plenum,Crane AFPR (50psi),MSD6AL,homemade cold air,K&Ns,3:73s,JET fan switch, Macewen white face gauges...ZZ9 cam is coming!
thanks guys.
'92 Formula
305 TPI
Ok, I was told the hotcam is too big for a 350 with Edelbrock aluminum heads. For sure this thing is way too big for a 305. The ZZ9 might be a better choice for your engine, man
[This message has been edited by JeffP (edited November 09, 2000).]
This type of cam would require you to change the valve springs. I would also suggest that you upgrade to roller rocker arms do to the extended rpm range of this cam. The rocker arms will not increase your hp but will give you more reliably from the valve-train. Also you are going to need a custom chip for the cam. If not the engine will run rough and would want to stall at idle. I run a similar cam in my 305 from comp cam and a love the power increase. Let me know if you would like more info on tuning issues
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
You're gonna need a lot of ***** to run a cam that big... Its designed for a high flowing 350 engine, not a TPI 305. Yes you'll need new springs for sure, at the very least.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
1991 Camaro Z28
13.25 @ 107.18 MPH
Southern California
My ***** are pretty big
Anyway you think its to much cam ? Because it lists being for the L98 and LT1.
Oh well.
Thanks anyway fellas
'92 Formula
305 TPI
[This message has been edited by theformula (edited November 10, 2000).]
Oh well.
'92 Formula
305 TPI
I'd reccomend about 78 more cubes first. While many will say the LT4 hot cam is a good 350 TPI cam, and I know TK's car runs like a raped ape with it, I still think its a little too big for a 350. I look at it as a really nice 383 port injected NA cam though.
-Jason M. 1991 Camaro Z28
"Its Blue."
"Its Blue."
installing a hotcam in that motor will make less power than the stock cam. but the idle will be lopier. If you want a good cam , call up crane cams or comp cams and they will recommend a cam. Dont waste your time with "popular cams"
Car: Death Mobile
Engine: 666 c.i.
Remember the old adage in hot rodding, bigger is not always better. This applies to carbs, intake port cc of heads, headers and camshafts.
However, it IS better if the bigger is cubic inches. Concentrate on that part first!
