Nader Declared Winner!!
Old Nov 9, 2000 | 03:55 PM
JRoy91RS's Avatar
Car: 91 RS Convertible
Engine: 355
Axle/Gears: 2.73 peg leg
Now that I have your attention. I'll finally be getting around to doing my 350 TPI swap this weekend (hopefully). Before I slap everything together, are there any suggestions that you all could give me? I was wondering what the common mistakes and overlooked aspects of the swap were. What should I do while the TPI is off the engine (as far as mods or prep work, etc.)? What would you have done differently? By the way, the system is an 87 MAF system (I think it's an 87). Thanks.
James
Old Nov 9, 2000 | 04:56 PM
Rob P's Avatar
Car: 89RSconvtZZ4TPI
Engine: ZZ4TPI
Transmission: 700R4 TRIPP TRANNY
Port the plenum while the motor is out.
Good luck
Rob P
89RSconvtZZ4TPI
92Z28convt5spd
71Impala convt 402BB
BETTER DRIVING THRU SUPERIOR HORSEPOWER!
Old Nov 9, 2000 | 08:31 PM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
Nader lost. Sorry, I don't respond to those tricks.
Old Nov 9, 2000 | 09:50 PM
JRoy91RS's Avatar
Engine: 355
You don't respond to those tricks?? It sure looks like you did to me! BTW, thanks for the help.
Old Nov 9, 2000 | 11:28 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Nevermind just the plenum, port-match EVERYTHING while you've got it apart. The base needs the most help.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
Old Nov 10, 2000 | 01:44 AM
F22Raptor's Avatar
Why waste your time with the stock base? Just get a new base and you'll be happier
'88 GTA 350
Headers, catback, free mods, Xtreme energy cam, and intake pieces
13.51@104.27, but can run better as it is.
I just put a new 2100-2300 RPM TQ Converter. I hope a 13.20 or better
RAPTOR, the baddest bird on the planet
AIM HIGH!
Old Nov 10, 2000 | 11:57 AM
rwelch's Avatar
In a previous thread on this board the following flow numbers were posted:
Runners
stock tpi 203cfm
Accel large tube 242 cfm
Extrude honed Accel 275 cfm
SuperRam 289 cfm
Base manifolds
stock 222 cfm
Accel 251 cfm
Accel extrude 276 cfm
Edelbrock perf RPM dual plane 286 cfm
If the stock base already outflows the stock runners, why is the base more important to mod?
Old Nov 11, 2000 | 06:14 PM
MIKES 88GTA's Avatar
I'm pretty sure those are ported #'s on the stock base.I read a post where a guy ported his base from one end to the other and got 2cfm less than an unported big mouth base (which is a ported edlebrock base)so with lots of porting a stock base will do anything you need and some SLP siamiesed runners portmatched to the plennum will go all the way to 5700rpm wich is plenty high on a stock bottom end sbc.
I would use felpro 1205 or 1206 intake gaskets to port match to the base and look at standard abrasives websites on porting heads and do as much as you feel comfortable with. With a good tune and fully ported heads and intake as well as the SLP runners you should be around 13.50's with the stock stall converter and maybe 3.27 gears(Depending on you cam).Good luck I hope it goes well for you.
Hawk312
Aug 22, 2017 08:55 PM
Linson
Nov 12, 2015 08:09 PM
Linson
Oct 1, 2015 09:50 PM
BlackphantomZ28
Aug 31, 2015 11:19 AM
BlackphantomZ28
Aug 22, 2015 01:00 PM
