Factory performance cam for 85TPI
Old Nov 18, 2000 | 08:55 PM
xclr8tr's Avatar
I have seen a GM Hot cam listed in a few signatures of members with 305 motors. Is it made for TPI or TBI? Exactly what kind of performance does this cam have? I live in Socal, so I need to consider smog-related issues when swapping parts. Any suggestions on a performance smog-legal 305 cam? The engine is a new Goodwrench and I don't want to swap in a 350.
Old Nov 19, 2000 | 01:57 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
The LT4 HOT cam is made for LT1 and LT4 4th gen engines. It is a roller cam and will not work in your 85 block. You need cams made for 55-85 chevy engines. You're in luck because these are much cheaper. However, I have no experience with non-roller cams. Hopefully someone else will post here.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
Old Nov 19, 2000 | 02:34 PM
xclr8tr's Avatar
I wasn't specific enough. The cam I was talking about apparently was the cam offered with the 305/5spd. I have read on the boards that it was rated at 230hp. I guess the question I need aswered would be is it worth swapping it in for the "Peanut cam" in there now? And would the computer chip for the auto work with this cam? Thanks for your assistance.
Old Nov 20, 2000 | 12:17 AM
Kevin91Z's Avatar
If you have an 85 TPI car, you already have the good cam, not the peanut cam. 85 TPI was the only 305 automatic TPI to not get the peanut cam.
Old Nov 20, 2000 | 12:34 AM
MrJ's Avatar
MrJ
Is that right?
Old Nov 20, 2000 | 12:27 PM
TransamGTA350's Avatar
Car: '89 GTA
Engine: ZZ6TPI
That is correct. The 85 305TPI came only with an auto and was rated at 215hp for the Camaro, and 205hp for the Firebird, due to a more restictive intake. It is the same cam as the 87 305TPI 5-speed, except is is not a roller cam.
89 Transam GTA, a few bolt ons
Old Nov 20, 2000 | 01:51 PM
Kevin91Z's Avatar
Originally posted by MrJ:
Is that right?
I wondered if you'd catch that. I didnt feel like editing it after I posted it.
Old Nov 20, 2000 | 03:37 PM
xclr8tr's Avatar
Thank you all for setting me straight on that one. (It still isn't enough hp for me!)
Vintageracer
Jan 10, 2020 05:33 PM
junkcltr
Aug 2, 2019 11:12 PM
beastin91rs
Oct 9, 2015 07:38 AM
MoJoe
Sep 24, 2015 09:12 PM
novaderrik
Aug 10, 2015 12:44 PM
