How to Change a Thermostat on TPI ???
Old Jul 8, 2007 | 08:55 AM
92RSFivePointSlow's Avatar
Car: 2002 Harley Nightrain
Engine: twin cam 88ci
Transmission: manual
The intake plenium is directly above the thermostat housing, what is the trick to getting the housing off to change the thermostat, or what needs to come off in order to do so? Thanks
91 Corvette with TPI.
Old Jul 8, 2007 | 09:01 AM
Jay's Avatar
Jay
Car: 88 IROC
Engine: 5.7 RamJet
Axle/Gears: Dana44 4.10
Re: How to Change a Thermostat on TPI ???
have to take the throttle body and plenum off to do it.
Old Jul 8, 2007 | 09:46 AM
That's how it was looking when I checked it out too, but I wanted to get a second opinion before ripping it apart. Thanks bud.
Old Jul 8, 2007 | 09:49 AM
Jay's Avatar
Jay
Car: 88 IROC
Engine: 5.7 RamJet
you'll most likely have to loosen the bottom bolts on the runners to be able to get the plenum out. If you are lucky and they don't rip you can reuse the runner gaskets. Be sure and check for vacuum leaks at the runners after putting it all back together. This is one reason why so many people dislike the TPI setup.
Old Jul 8, 2007 | 10:03 AM
ibmtech's Avatar
Car: 1987 IROC-Z
Engine: TPIS II Supercharged w/Nitrous
Transmission: 700R4 Probuilt
Axle/Gears: 3:73 Richmond 12 Bolt
I just had to remove the throttle body to change mine out.
Old Jul 8, 2007 | 10:21 AM
Jay's Avatar
Jay
Car: 88 IROC
Engine: 5.7 RamJet
That may be the case.
I'm trying to remember... I thought on one of mine I had to remove the plenum because the back bolt I couldn't get a socket on to with just taking the throttle body off.
Old Jul 8, 2007 | 10:31 AM
ibmtech's Avatar
Car: 1987 IROC-Z
I used a swivel socket on a 3/8 extension to get it off. I do remember that it was kind of pain in the butt to do this but it was doable.
Old Jul 8, 2007 | 08:57 PM
GTA Jim's Avatar
Car: 1990 GTA
Engine: 5.7
Transmission: 4L60
Axle/Gears: 3.27 Posi
Yea, just the throttle body. - You don't need to touch the plenum. Be careful of some fine vacuum lines hooked up under the throttle body as you pull it off. They are plastic and break easy.
If you've got lots of patience, you can remove the two thermostat housing bolts with a long wrench that has an open end on one side and a box end on the other. I've never tried it with a swivel socket
Old Jul 8, 2007 | 10:03 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
Yes, just remove the TB, and get a set of those extensions which lock up at about a 5 degree angle from straight.
Old Jul 9, 2007 | 10:17 AM
8T9 BANDIT's Avatar
Car: 1989 T/A
Engine: PROCHARGED LB9
Transmission: FB BUILT 700r4 2200 stall
Axle/Gears: 10 BOLT EATON 3:73 POSI
ive done mine twice without removing anything? just the intake duct to the tb.
Old Jul 9, 2007 | 10:41 AM
ranone21's Avatar
Car: 1989 Trans Am t-top WS6
Engine: 305 tpi
yes me too... I have taken it off with a wrench and not bothered anything else except the ductwork
Old Jul 10, 2007 | 09:39 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
A lot of it depends on how recently you've had things apart. Steel bolts in aluminum parts can be a bear to get apart if they haven't been apart recently. If your thermostat housing bolts haven't been out in some time, you may want to take the throttle body and/ plenum off so that you can use a 6 point socket on them. If things have been apart recently, you can probably get away with some combination of wrenches or other tools that don't require pulling the throttle body off.
But... pulling the throttle body off is a 5 minute job, and it almost never tears the gasket. I don't see why you'd want to struggle with the thermostat housing instead of just taking off the throttle body.
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Wade787b
Sep 29, 2015 01:15 PM
jbd1969
Aug 17, 2015 07:06 PM
perZ
Aug 15, 2015 01:17 PM
Sanjay
Aug 12, 2015 03:41 PM
