Will they work??
Old Dec 2, 2000 | 11:03 PM
ADMZ24's Avatar
Car: 1991 Trans Am
Will they work??
I need injectors for my 91 trans am 305 TPI. Will injectors from a 1996 LT1 Work??
Also, what causes injectors to go bad? The car had 152,000 miles, is it time for them to die???
Old Dec 3, 2000 | 05:54 AM
Ski89Z28's Avatar
Those injectors will not be good for your 305 since you need 19# injectors and the LT1s are 24# injectors.
You'll run too rich.
Sometimes the tips crack and leak fuel or the solinoid in them goes bad or even a clogged screen in them.
There is someone that does rebuilds on injectors for like $10 each and I heard he does a great job.
Here it is: http://www.cruzinperformance.com/
Check out the injector cheaning.
Good Luck!
Old Dec 3, 2000 | 09:00 PM
ADMZ24's Avatar
Car: 1991 Trans Am
If the injectors will fit, can i change my computer and make them work??
Old Dec 4, 2000 | 11:56 AM
Ski89Z28's Avatar
I wouldn't really recommend it for a 305.
If it is stock it could hurt you more than help. Then even with a cam and heads I really don't think it would be wise.
Anyway.
You would need a adjustable fuel pressure regulator first. Then you would need a custom chip programmed and if you don't do the programming yourself and have the equipment then you will need to buy one for around $300! Or by the equipment to do it yourself.
Either way it cost you over $300 and for that you could get new injectors for that! I think summit sells some ACCELL 19# injectors for around $250.
Good Luck
Terrell351
Jun 13, 2021 01:13 PM
Jake_92RS
Jan 28, 2020 10:37 PM
Vintageracer
Jan 10, 2020 05:33 PM
Jk_Under
Aug 17, 2015 03:08 PM
Fronzizzle
Aug 17, 2015 02:52 PM
