Easy Yes No answer
Old Dec 7, 2000 | 09:29 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
Easy Yes No answer
I got a 350 TPI Ported Edelbrock Intake, Ported AS&M Runners ,Ported Plenum ,Full Ignition ,Full Exhaust ,1.6 RR's ,Custom Chip ,afpr. I got a airfoil should i get 52MM TB? YES NO ?
Old Dec 7, 2000 | 09:59 PM
Blade's Avatar
Simple: Yes. Advanced: It can't hurt, it will only help.
92 Z28 L98 350
Ported stock heads, XR270HR-10 cam, TES headers, Crane AFPR, Flowmaster catback, MSD ignition components.
Best ET 12.9@107 mph
"Take that auto, drop it in first, hold the brakes, stomp the gas and grin from ear to ear! :-)
Click here to see my car at Truspeed.org
Old Dec 8, 2000 | 11:04 AM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
YES.
'87 L98 TPI IROCZ, AFR190 heads, 3.70 gears, ZZ9 cam, 2400 Art Carr TC, SLP 1 3/4" headers, SLP cat-back, no cat, no AC, no MAF screens, Accel manifold base & SuperRam, Edelbrock double roller timing chain, MSD ext coil & distributor, trans cooler, 52mm TB with airfoil, TB coolant bypass, AFPR(58psi), K&N filters, Hotchkis lowering springs, Car-Pro custom chip, Lay Ind. ram air kit, 265/45R16 Kumho V700 tires.
ET 13.39sec @ 107.21mph
'90 Eagle Talon AWD, no rust thru 9 winters
'99 Camaro SS, red, 6-spd, T-tops, Mcleod clutch, Pro 5.0 shifter, MAF processor, Direct Flow airlid, K&N filter.
313.7Hp & 320.6ft-lbf, ET 13.55sec @ 105.1mph
next mod: 4.10 rear gears
Old Dec 8, 2000 | 06:42 PM
IrocManiac's Avatar
Go for it!!!
TPI 305,
Gutted airboxes,
gutted MAF,
K&N filters,
Corvette Servo.
14.9@93mph
"Speed kills, wanna live forever, drive a Ford."
Old Dec 8, 2000 | 09:10 PM
black5.7GTA's Avatar
Yes,get the ED/BBK one.
1990 Trans Am GTA
Bosch plat+4 plugs,SLP plug wires,Hypertech coil kit,Fastchip PROM,SLP 160 therm,T-body bypass,SLP crankpulley,Breathless AFPR,,ported plenum,SLP runners,SLP flowbooster,SLP cold air,K&N,SLP 3"catback,SLP torqueconverter,SLP shiftkit,Mobil 1
14.3@96 stock
13.5@102 w/mods
Old Dec 8, 2000 | 10:12 PM
irocz's Avatar
Car: '87 IROC-Z
Engine: 406 Superram/DFI
Transmission: Auto BTE 3000 conv
NO, spend your money on some good headers first.
87 IROC-Z, 5.7, auto, 3.27, leather, !cat, Holley fpr, K&N'S, SLP 1-3/4" Jet-Hot coated headers, SLP .218/.224 .495/.502 cam, Comp 1.5 roller tip rockers, $uperPITAram, Edelbrock lower intake, Holley 52mm tb, Dynomax\Flowmaster catback. Coming Soon(?)- Fasttrack/Accell DFI
1989 Pontiac 20th Anniversary Turbo Trans Am - 161,000 miles, !cat, 9" K&N
Old Dec 8, 2000 | 10:15 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
I got headers
Old Dec 8, 2000 | 10:27 PM
MIKES 88GTA's Avatar
There's been a lot of tests floating around in magizines and such that show that a 48mm is fine up till 400 or more horespower,besides that the MAF sensor (even fully ported) wouldn't flow as much as a 58 or52mm throtle body . so no, not a wise investment.$300 bucks, get a staLL converter.
Old Dec 8, 2000 | 11:42 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
A fully modified MAF will flow 750cfm (TPIS #'s) and a 52mm throttle body flows 750cfm as well. I will argue on the quality of the BBK/Edelbrock tb's as I think they lack quality (I own one). When I got mine the are in between the throttle bores were still rough cast and I had to contour it to shape with a few different files. I was rather pissed it wasn't a nice machined finish as the pic. shows in JEGs. THe only good thing about them is they are one of the cheaper priced tb's to buy. Guess its a get what you pay for kind of thing or else I just got screwed by JEGs with a bunk tb.
The stock tb flows 668cfm on it's own and 709cfm with an airfoil,, so really you're not increasing your flow potential (40cfm) enough to make the car sprout wings.
I'd have to go with no,, don't bother,, I wouldn't have but my stock one was wore out and had to much play in the throttle blades to where I'd have to tap the gas every time stopping to get the idle to settle back down.
Da Boid
- 4 out of 5 people think the 5th is an idiot
[This message has been edited by deadbird (edited December 08, 2000).]
Old Dec 9, 2000 | 09:05 PM
irocz's Avatar
Car: '87 IROC-Z
put your headers in your sig!
if you get an aftermarket tb, get a holley. they have a smooth transition between the bores (unlike bbk), and they're cheaper. The only thing I had to do on mine was put 1 washer between the tps and tb so the tps arm would move freely.
cheesehomer
Dec 31, 2015 08:48 AM
HoosierinWA
Oct 7, 2015 10:15 AM
3.8TransAM
Oct 1, 2015 07:47 PM
kkirch15
Sep 30, 2015 04:44 PM
92projectcamaro
Sep 29, 2015 07:07 PM
