timing adj?
Old Dec 9, 2000 | 10:48 AM
jmon92conv's Avatar
timing adj?
Ok folks, I am new to the computer controlled motors so bear with me. I am wondering about adjusting the timing for a little better performance. How do you do this with the 92 tpi's? Is it worth it and with a close to stock motor where do you suggest setting the timing?
Thanks all,
Jeremy
92 Z conv
5-spd B&M
alston SFC, few mods, some free, some not
Old Dec 9, 2000 | 12:33 PM
ede's Avatar
ede
unplug the est wire and set it like you would on any other car. the est is a brown wire w/tan stripe near the blower box. it's a single wire, maybe inside a wire loom. plug it in when you're done. if anyone has done this before it may be hanging out of the loom.
ICON Motorsports
1st & 3rd
Old Dec 9, 2000 | 12:51 PM
jmon92conv's Avatar
thanks, where would you suggest setting it at?
Jeremy
92 Z conv
5-spd B&M
Old Dec 9, 2000 | 03:34 PM
Stell1579's Avatar
i believe how the computer works is it will add 22 deg. more timeing to the base (base is set when you ajust the dirstributer) stock is set @6DBTDC so that would give a max of 28 deg. i have my base @ 8 deg. so that would give 30 btdc
someone correct me if i am wrong
-Stell
1988 IROC 305TPI MINT!!
Mods= Accell SuperCoil, MSD 6A, Ported Plenum, No MAF Screans , K & N, 160 Thermostat+ Temp Switch, Relocated MAT, Cold Air
Old Dec 9, 2000 | 04:29 PM
87Z-ya's Avatar
Anyone know where the est wire is on a 87 monte carlo ss?
87z 383,afr 190's, crane hyd roller(224/230-.509/.528,112 sep),Ported and polished mini ram, 30lb inj, 3.42 gears, strange 12 bolt, tremec 5spd, , 1,3/4" slp headers.
Old Dec 9, 2000 | 04:33 PM
fly89gta's Avatar
Car: 2018 Camaro SS
Engine: LT1 w/Paxton 1500SL
i have my base timing set at 8*...plus my Stage 2 fastchip advances it some more...stock is 6* when i got the car the guy i bought it off of had it at -2*!!!! he said it was pining...i've yet to have a ping...i think the guy was smoking crack!
89 GTA
Originating memeber of the SJNEP crew
Rice....it's whats for dinner
check out the car here:
http://www.hometown.aol.com/clarkemustgonow
Tony
Old Dec 10, 2000 | 08:12 AM
jmon92conv's Avatar
thanks for all the info. That gives me something to do now
Jeremy
92 Z conv
5-spd B&M
1992rs/ss
Jan 31, 2025 05:10 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
