Need help choosing select parts for a 383 L98
Old Dec 7, 2000 | 08:42 AM
GlennS87's Avatar
I’m having my ’87 L98 stroked to a 383. It’s being built by a local engine builder. The car is a daily driver and must be able to handle We’re using a cast crank, forged 6” rods and forged pistons. He’ll be re-working my aluminum L98 heads(porting, competition valve job, larger valves,etc..) . I’m trying to re-use as many existing parts as I have. Compression will be between 10-10.5. The car must pass NJ emissions. Obviously a custom chip is in order also.
This includes:
Modified maf, 52mm TB, ported plenum, big mouth manifold, APFR
I will probably get an AS&M semi-siamesed LTR as a $$ compromise. It’s about $200 cheaper and I don’t have to get a 58mm TB for the time being. I need to provide the following:
1. camshaft(can I reuse my exist hyd roller lifters?)- I’m leaning towards LPE 219, poss. upgrade to SR in a couple years
2. roller rockers(builder said aluminum is fine, I’m thinking 1.6 ratio) specific part recommendations?
3. long tube headers
4. fuel injectors- in the interest of saving $$, can I reuse my existing injectors? They are stock flow but previous owner put on Rochester blueprinted injectors
5. custom chip- considering Fastchips or having a chip burned while being dyno tuned locally(Ida automotive, Morganville, NJ)
I’ve read John Lingenfelter’s Modifying small blocks and TPIS insider hints. Between this and following this great forum, I’m suffering from information overload. I would appreciate any suggestions.
Thanks in advance
Neptune, NJ
White '87- modified maf, TPIS big mouth manifold, SLP siamesed runners, no pre-cats,hi-flo main cat, Walker Ultra flows and y-pipe w/crossover,ported plenum,adj. fuel pressure reg.,cut out air filter cover,
auto(trans kit,shift kit), 2300 stall converter, k&N filter, 3.07 rear diff., Silver ZR-1 wheels 17x9 and 17X11
Old Dec 7, 2000 | 09:43 AM
Paul Riccioli Jr's Avatar
Car: 89 IROC-Z
Engine: 383
I'm reusing my stock lifters. I would go with some nice roller tip rockers from someone like comp or crane. As far as injectors go I think you would be better off going with 24# injectors because the factory ones probably won't cut it.
Where is this Dyno that you know of in NJ? I would love to dyno my car when it's done.
Riccioli Performance Motorworks
--RPM Racing--
-Currently building first ever engine. 383 with Super Ram plenum and runners, Edelbrock lower intake, Bosch 24# injectors, either AFR or Trick Flow heads, MSD ignition.
-Will be installing Baer Brakes
-Will be installing full Spohn suspension in rear
-Art Carr 700R4 trans??
Old Dec 7, 2000 | 09:55 AM
GlennS87's Avatar
The place is Ida automotive in Morganville, NJ. There web site is www.idaautomotive.com.
Neptune, NJ
Old Dec 8, 2000 | 06:31 AM
blak92!'s Avatar
Paul,
WIld Rides and Pat Musi's in Carteret has chassis dynos.
Old Dec 8, 2000 | 08:32 PM
87Z-ya's Avatar
If you have a good engine builder this shouldnt be a problem but make sure to have your rods clearanced for the cam. When I started off on my 383 project I used the L98 cam to get it dialed in at first and got away with the stock injectors.
87z 383,afr 190's, crane hyd roller(224/230-.509/.528,112 sep),Ported and polished mini ram, 30lb inj, 3.42 gears, strange 12 bolt, tremec 5spd, , 1,3/4" slp headers.
Old Dec 8, 2000 | 08:43 PM
Car: 89 IROC-Z
Engine: 383
87z-ya......do you know if you always have to clearance the rods? Unfortunately I already had my rotating assembly balanced and I didn't have them clearanced. I'm really starting to worry that I'm going to have problems upon assembly.
--RPM Racing--
Old Dec 8, 2000 | 10:19 PM
irocz's Avatar
Car: '87 IROC-Z
Engine: 406 Superram/DFI
Transmission: Auto BTE 3000 conv
You'll be better off getting your lift from the cam rather than 1.6 rockers. Less stress on the valvetrain in the long run. You'll be fine reusing the stock lifters BUT you must make sure they are in the same hole they came out of and in the same orientation. If it's too late, you'll probably be alright, but I wouldn't take the chance.
87 IROC-Z, 5.7, auto, 3.27, leather, !cat, Holley fpr, K&N'S, SLP 1-3/4" Jet-Hot coated headers, SLP .218/.224 .495/.502 cam, Comp 1.5 roller tip rockers, $uperPITAram, Edelbrock lower intake, Holley 52mm tb, Dynomax\Flowmaster catback. Coming Soon(?)- Fasttrack/Accell DFI
1989 Pontiac 20th Anniversary Turbo Trans Am - 161,000 miles, !cat, 9" K&N
Old Dec 9, 2000 | 01:17 PM
87Z-ya's Avatar
In almost every situation with a stroker you have to clearance the rods. The only way around it is to get a small base circle cam (but that leads to other problems). I used to work in a machine shop and its not a big deal if you already had it balanced. Your taking a few grams of the big end so its not that bad. Put your engine together and slowly work in the cam. Turn the motor over by hand and look at where the rods are hitting the cam. If your rods are similar to stock rods the top of the rod bolt on the inside of the rod will hit. With most cams its cyl 2 and 6 that are the worst but I grind down all of the bolts to aid with future cam swaps. If you have rods with cap type screws you may have to grind a little off the rod itself or maybe not at all. Install the pistons without the rings when you do this proceedure and mark each piston to where you put it in at. You will want a clearance of .020 to aid with expansion. If you do it right you wont have any problems and the balance wont e affected drastically.
Old Dec 11, 2000 | 08:59 AM
GlennS87's Avatar
Thanks for the great feedback. Keep the good ideas coming. The motor is being removed on Wed. 12/16 and going to the builedr. I have to order these parts asap.
Neptune, NJ
White '87 Vette- modified maf, TPIS big mouth manifold, SLP siamesed runners, no pre-cats,hi-flo main cat, Walker Ultra flows and y-pipe w/crossover,ported plenum,adj. fuel pressure reg.,cut out air filter cover,
Old Dec 11, 2000 | 10:44 AM
pat85yellowroc's Avatar
i would go with the ford svo injectors. save a lot of money and ive heard they work just as well.
beau-t-ful yellow 85 iroc
Old Dec 11, 2000 | 11:06 PM
dan's Avatar
dan
a lot of forged rods are built to clear the cam in a stroker motor.
Old Dec 12, 2000 | 10:32 AM
GlennS87's Avatar
Where's the cheapest place to buy the Ford SVO 24lb injectors?
Neptune, NJ
Old Dec 12, 2000 | 01:07 PM
MikeH's Avatar
Car: 90 IROC
Engine: 406
Transmission: GMPP 93/4L60
Axle/Gears: 9 bolt 3.27
Summit racing has the 24s for about 200.00 a set. Thats where i bought my 30s.
Black 90 IROC, L98, A4, 323 gear. SuperRamed 406 in the works!
Old Dec 12, 2000 | 08:25 PM
89IROCZ
Guest
Posts: n/a
Glen.... your from Neptune, NJ? I am from Ocean township... you might have seen me around before, or vice versa.
1989 IROC-Z
350c.i. TPI
rebuilt 700R4 with shift kit
3'' Monza Pacesetter cat back exhaust (minus the muffler)[SOUNDS OF THIS ON MY WEBPAGE]
new dual cats
3.23 Posi rear
hypertech chip
under drive pulleys
adjustable fuel pressure regulator
K&N Air Filters
Excalibur alarm, keyless entry and remote start
new:
struts, shocks, bearings, distributor, cap, rotor, alternator, battery, regulator
245 ZR16 50 Tires, Rotors and brake pads all the way around
Go to my webpage to find out more about it.
You can also see pictures, and hear sounds as well.
http://go.to/iroc-z
AOL IMer: JRShotliff
Old Dec 12, 2000 | 09:59 PM
GlennS87's Avatar
89IROC7,
I only went to Englishtown a couple times this past year. I didn't feel the car was running right. Next year with the new motor I'll be making a few more trips.
Neptune, NJ
Old Dec 23, 2000 | 07:22 AM
86IrocZ383's Avatar
One thing on the cam selection, instead of a $400 LPE cam I would recommend a Comp Cams XR270 on a 112 LSA. It has 218@.050 intake and 224@.050 exhaust duration with .495/.502 lift with 1.5 rockers. I have this in my car and it idles fairly smooth and pulls to 6000 rpm
86 Iroc, 383 Ported Sportsman II, Ported RPM Airgap, 750 Holley Vac. Sec., Slp 1 3/4, Comp Cams roller 218 224, 10" 2600 stall, Fairbanks 700r-4 W/superflow pro pump, 9" disk 3.70, 12.969@106.54 1.991 60', new times in spring
87 K30 Chevy P/U 355 TPI Crane Compucam, Ported heads TH400, headers and 2 1/2 duals, flowmasters, 8" lift, 36" super swampers, 4.10 detroit lockers,
LT1Formula
20
Nov 14, 2015 12:02 AM
armybyrd
Aug 17, 2015 08:59 AM
GVMV
Exterior Parts for Sale
Aug 16, 2015 07:08 PM
sreZ28
Aug 14, 2015 07:48 PM
1nastygta
Aug 8, 2015 07:38 PM
