Best engine combo from these parts.
Old Dec 26, 2000 | 10:33 AM
Coolcars's Avatar
I own way too many parts and I need to start using them. What is the best way to go?
I have a complete 305 TPI with a bad bottom end.
I have a 67 327 with 202's ect. runs great fresh heads. Option 1, install tpi on this motor.
I have a 96 Vortec 350 out of a truck with 16000 miles on it complete motor no wiring or computer? Option 2, buy the vortec base when it comes out and install tpi on this motor.
Option 4, buy a crate 350 and install the tpi on it. This is my least desirable option since I need to use some of the parts that I already own.
Option 5, Get a 350 short block and install a set of old style 202 heads and tpi. Not my favorite option but I do have three sets of these heads.
Option 6, I don't know do you guys have any suggestions.
2E,87 Formula 350,with coolant bypass and 160 thermostat and chip. 1986 Z28 with 327 & 202 heads and 5 speed, and usually 4 or 5 others Camaro's & 3 Firebirds to fix, Drive, or sell.
Old Dec 26, 2000 | 02:42 PM
ede's Avatar
ede
i'd use the truck engine and tpi. as much as i like the 327 tpi on it's a bad choice. the 327 is a rpm loving engien and makes its best power at higher rpms the tpi is a low end induction set up.
ICON Motorsports
1st & 3rd
Old Dec 27, 2000 | 08:19 AM
ws6transam's Avatar
Car: 1984 Trans Am WS6
Engine: Minirammed 385, 396 RWHP
Axle/Gears: 3.73 Moser 12-bolt
Ede is right on this one;
Use the Vortech 350 engine. Upgrade the cam and valvetrain, and add the SDPC2000 Vortech TPI manifold. Sell the 327 to a collector; Put the 305 block (less TPI) in the newspaper's classified ad column under "free".
These days, 202 heads are hard to justify rebuilding when you can get such great castings from the aftermarket. Unless you have the tools to recondition them yourself, consider turning them into cash.
[This message has been edited by ws6transam (edited December 27, 2000).]
Azrael91966669
25
Jun 20, 2017 04:04 AM
Caspar
Jun 19, 2016 11:19 PM
IMissMy86TA
Aug 31, 2015 08:40 PM
InfinityShade
Aug 22, 2015 08:00 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
