Corvette servo???
Old Dec 30, 2000 | 09:47 PM
RoadRocket L98's Avatar
Corvette servo???
I've seen people listing this in their signatures, what exactly does this do?
'83 Firebird 2.8
'89 Firebird Formula 350
2nd owner, red/grey, t-tops, dual cats, and a 3.27:1 rear
K&N, TB bypass, No MAF screens, CAI
Old Dec 31, 2000 | 01:35 AM
Dan W's Avatar
A part of an automatic tranny. Allows for a faster/firmer shift.
Old Dec 31, 2000 | 10:53 AM
IrocManiac's Avatar
It allows for harder and quicker shifts just like above, but it also selects the gears better. For instance it holds the gears a little bit longer even under part throttle acceleration.
TPI 305,
Gutted airboxes,
gutted MAF,
K&N filters,
Corvette Servo.
14.9@93mph
"Speed kills, wanna live forever, drive a Ford."
Old Dec 31, 2000 | 11:30 AM
Where can I get one and how much? Thanks!
'83 Firebird 2.8
Old Dec 31, 2000 | 11:44 AM
MrJ's Avatar
MrJ
Are you sure about that Irocmaniac? I thought shift points were controlled by the governer.
91 Trans Am WS6
Bright White
5.0 TPI auto
Flowmaster 3" 2 chamber catback
Trans Go shiftkit
2000 stall converter
Built on Wednesday
Old Dec 31, 2000 | 12:21 PM
IrocManiac's Avatar
You could possibly be right, my tranny guy told me that it made it hold the gears longer. I was worried when I first got it back because it would hold first gear to 9-10 mph whether or not I was or wasn't accelerating and before it would shift to second as early as 5 mph. Well I called him and he said it is the Corvette servo that makes it hold the gears longer. However I may be wrong or misunderstood him, it happens from time to time. GMTech would be really good at answering this question if it were reposted in the tranny section.
TPI 305,
Gutted airboxes,
gutted MAF,
K&N filters,
Corvette Servo.
14.9@93mph
Old Dec 31, 2000 | 01:46 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
I will answer it right here for ya. The Vette servo shifts faster because the size of the apply piston is smaller. Its really simple, but you would have to have a small background in hydraulics to understand. Tightening up in the TV cable, or changing the spings or weights in the governer will hold shifts longer. The servo will just make it firmer by doing it faster.
Heres a little more info: Vette Servo
If you live in Southeastern US, check us out!
South East Thirdgen
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey, 22# injectors,
JET AFPR, Ported Plenum,
TB Coolant Bypass, Custom Cold Air,
SSM SFC, KYB Shocks, Boxed LCAs, Wonder Bar,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
-->14.97 @ 94.9 MPH<--
'97 Bonneville SSE
Old Dec 31, 2000 | 08:41 PM
wm_sorg's Avatar
Car: 1991 Formula Firebird
Engine: 2001 LS1 Modded
Transmission: 2001 4L60E Yank SS3600 TC
How do you adjust the TV cable? Will additional tention be created causing the cable to hit it's limit in movement?
Old Jan 1, 2001 | 09:09 AM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
You can "ratchet" it back a tooth or two, but when you really drop the hammer (WOT) it may ratchet back out. YOur best bet is to probably play with the governer.
South East Thirdgen
Savannah, GA
'87 Trans Am
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
'97 Bonneville SSE
the_hamturdler
Sep 30, 2015 12:50 PM
dusterbd
Sep 29, 2015 08:40 AM
dbrochard
Wheels and Tires
Sep 25, 2015 05:40 PM
Dragonsys
Sep 25, 2015 03:51 PM
italiano67
Sep 22, 2015 08:42 AM
