Comp XFI280 Cam
Old Jul 28, 2007 | 09:17 PM
VincentZ28's Avatar
Car: 1990 G92 IROC Z Miniram
Engine: 388cu 6.4 Liters
Transmission: G-Force T5
Axle/Gears: 3.73 Gears
Comp XFI280 Cam
Does anyone have anything good to say an/or has gotten good results from this cam?
Old Jul 28, 2007 | 10:20 PM
Guest
Guest
Posts: n/a
Re: Comp XFI280 Cam
No results at all. lol
Whats the matter, dont like your Lunati anymore? Go solid roller.
Old Jul 28, 2007 | 11:39 PM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Re: Comp XFI280 Cam
It was lonely at the top, now he feels he has to much company.
Old Jul 29, 2007 | 01:38 PM
Guest
Guest
Posts: n/a
Re: Comp XFI280 Cam
Did you port those heads? I'd do that first, if you havent already. And with more duration you can run more compression so... may as well replace pistons.
Get a solid roller with more lift.
Old Jul 29, 2007 | 03:35 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: Comp XFI280 Cam
so far i've heard a few good things about that cam... more so with the XFI series. the 268 is a hot cam for TPI setups. 280 is better for 383's and larger. lift is not bad with 1.6 rockers. its up near .570 i believe.
Combination motorsports sells some custom high lift grinds that have similar duration with lift up near .612 lift with 1.6 rockers. try that over a solid roller, i'm curious as to how that cam would react in a nice 383 longblock
Old Jul 29, 2007 | 03:44 PM
LB9GTA's Avatar
Car: '91 GTA
Engine: 421sbc
Transmission: Powerglide
Axle/Gears: Ford 9" with 3.89
Re: Comp XFI280 Cam
I have it
It is on a 383 sbc gen 1 with the LT1 intake.
It idles well, but I had to increase the idle speed to 750.
As for power, it propelled my 3650lb car (with me in it) in the 1/8th mile for an et of 8.1 @ 84.
All the mods are in the sig. That is with a 48mm throttle body, 24 lb injectors and 1 5/8 shorty headers, which are all restrictions for me.
Old Jul 29, 2007 | 07:07 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
Re: Comp XFI280 Cam
Subscribing to this thread for the entertainment value.
Old Jul 30, 2007 | 10:28 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
Re: Comp XFI280 Cam
I have one in a 305 TBI small block. Ran 11.80s in the 1/4 with a 1.95s 60' time.
F.I. 57 Belair
Aug 23, 2021 01:09 AM
Jorlain
Oct 8, 2015 01:57 AM
customblackbird
Oct 1, 2015 04:30 PM
sandman92084
Sep 12, 2015 10:27 PM
Strick1
Sep 4, 2015 07:11 AM
