Question for all you 5speed 305 TPI guys
Old Jan 6, 2001 | 08:38 PM
theformula's Avatar
I'm currently getting a chip burnt by Ed Wright. Can anyone give me recommendations of what RPM I should be shifting at in WOT . You can see my mods in sig below.
91 Formula
305 TPI 5speed
1LE/G92/WS6
Custom K&N cold air intake, SLP airfoil, ported & hi-polished plenum, March pulleys, TB coolant bypass, 180* stat, Crane AFPR (47psi),94 octane,Crane Extruded Alum. 1.6 full roller rockers, Timing set from 4*BTDC to 10*BTDC,MSD coil,MSD6AL, Holley 9mm Annihilator Laser shot 50 wires, Ac Delco cap,rotor and plugs, Bosch O2sensor, SLP 1 5/8 headers,SLP catback,3:73s,JET 195* fan switch, Macewen white face gauges, Autometer gauges, Zoom hi-performance clutch.
Street legal with stock throttle body, runners,intake manifold,cam, and heads.
[This message has been edited by theformula (edited January 06, 2001).]
Old Jan 6, 2001 | 11:49 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Since you have the stock intake manifold, probably around 4600 or so. I am able to feel mine give up and stop pulling. You should shift just before that.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
Old Jan 6, 2001 | 11:53 PM
theformula's Avatar
I think you're right Kevin. Actually my peak hp is at 4600 if I'm not mistaken. How much more RPM would an aftermarket intake manifold give me?
Old Jan 7, 2001 | 12:49 AM
MrJ's Avatar
MrJ
4600 is low as hell to shift. I've got an auto car, but I shift 1-2 at 5300, and 2-3 at 5100. 4600 = short shifting and will hurt ETs.
91 Trans Am WS6
Bright White
5.0 TPI auto
Flowmaster 3" 2 chamber catback
Trans Go shiftkit
2000 stall converter
Built on Wednesday
[This message has been edited by MrJ (edited January 06, 2001).]
Old Jan 7, 2001 | 11:06 AM
JohnnyIroc's Avatar
Car: 85 TA
I think shifting at 4700 rpms is the best shift point. I got my best timeslip shifting at that rpm range and you shouldnt shift before 4700 and no later than 5000 rpms especially with the 3.73 gears, which I have also. Good luck
88 Iroc 305 TPI 5 speed
Performance Resource Chip, Flowmaster American Thunder cat back exhaust, B&M Ripper shifter, MSD coil, TB bypass, TPIS MAT relocation kit , TPIS 170* t-stat, Richmond 3.73 gears, March Power & Amp pullies Home made Ram Air
Best et: 14.338
Best mph: 96.97
Best 60': 2.106
http://hometown.aol.com/famioso15/johnnyiroc.html
Old Jan 7, 2001 | 12:12 PM
Abe91Z28's Avatar
MrJ my car shifts @5500 1-2, and 5100 2-3 i really wish it would shift around 5000 because i can feel the car losing power after the 5000 also, when you shift does the car shift for you, or when you take it in to 2 will it shift right away? On my car for example @ WOT i can move the shifter into 2 around 4800 and the car will AUTOMATICALY go to 5500. it really gets me mad. Does your car do that? When i'm not @WOT and i shift, it will go into gear right away. But, hey i guess thats why its called and automatic
-Abe
1991 Z28 305 TPI.
Mods: Hypertech Airfoil, gutted airboxes, K&Ns,polished 91' rims (they turned pink!), and all rear end bushings & tranny mout are energy suspension poly ones now
MORE TO COME: Any suggestions on what to do next? I really want to try and make the 305 run 13s (i've mostly been doing basic repair to the car, but now most of its done i have money to mod!)e-mail me@ abraham_39@hotmail.com
[This message has been edited by Abe91Z28 (edited January 07, 2001).]
Old Jan 7, 2001 | 05:38 PM
MrJ's Avatar
MrJ
I've got a Trans Go shiftkit. I can hold any gear as long as I want But the tranny shifts, automatically, at a little over 5000 for 1-2, and about that for 2-3 also.
91 Trans Am WS6
Bright White
5.0 TPI auto
Trans Go shiftkit
Built on Wednesday
Old Jan 7, 2001 | 08:46 PM
87Z-ya's Avatar
Loosen up the tv cable and it will shift sooner. It will probably shift to soon in normal driving though.
84z96L31vortec
Aug 20, 2017 12:16 AM
st.evel07
Aug 13, 2015 06:15 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
drathaar907
Aug 6, 2015 04:20 PM
