Need A Cam for Stock 350 TPI
Car: 92 Z28
Engine: aint got no engine right now
Transmission: need one of those
I have stock 92 350 TPI and one or more valve seals on my engine have decided to start leaking. I have come into a set of stock heads that I will be using to replace the ones currently on the engine. I figure that since I have the heads off, I could upgrade the cam while I am at it. The car is stock with the follwing done:
Ported Plenum, portmatched plenum, runners, and lower intake, AFPR, airfoil, low resistance wires (TPIS), timing @ 8*, Edlebrock headers (1 5/8), Flowmaster cat back exhaust.
If anyone can recommed a good cam that will work well with this set up and be under $200 I would appreciate it. It would be great if I could get 20hp to 30hp out of a cam change.
Thanks,
Eric
Thanks,
Eric
if you keep the factory hydrolic roller you won't find a cam under 200 that i know of. you could change to a regular hydrolic and lifters and change push rods.
ICON Motorsports
1st & 3rd
ICON Motorsports
1st & 3rd
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
The ZZ4 cam is under $200 from GM, but you'll need new valve springs to handle the lift, which makes it over $200 total. Most roller cams start at $225, but they're worth it. See the cam article in the tech section here for suggestions. Pick one in the 206-212 intake duration range, and under .480" lift if you're keeping the stock valve springs.
West Coast GM Shootout 2001!
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
1991 Camaro Z28
13.25 @ 107.18 MPH
Southern California
Car: 92 Z28
Thanks for the response guys. The $200 price was a number that I wasnt sure about but was just hoping to stay under. I can go over that but I am trying to avoid the Ligenfelter and TPIS price tags that I know comes with those cams.
The LT4 HOT Cam cost me $184 with shipping from www.gmpartsdirect.com. Our cars have almost the same mods done, and it seems to be a good fit for my car.
1987 Chevy Camaro IROC-Z
L98 TPI 350 (5.7L)
TH 700R-4 Transmission with 2.77:1 Rear End
Current Mods: Edelbrock TES 1 5/8" Headers, Hooker 3" Aerochamber Cat-Back System, Performance Resource Chip with 160* Thermostat, LT4 HOT Cam, Accel Ignition Coil, Cap, Rotor, 8.8mm Wires, K&N Filters, JET TPI Air Foil, All Free Mods, Falken ZIEX Z-Rated Tires.
Best ET (w/o LT4 cam): 14.32 @ 97.7mph
(corrected for elevation)
L98 TPI 350 (5.7L)
Sanjay
Aug 12, 2015 03:41 PM
