LT1 CAM SWAP
Old Aug 1, 2007 | 07:49 PM
1987ZTPI's Avatar
Car: 1987 IROC-Z
Engine: 310 lb9
Transmission: SEMI STOCK 700R4
Axle/Gears: 3.45 9 BOLT
LT1 CAM SWAP
i'm looking at doing an LT1 cam swap in my 87 lb9 it has 081 heads and i was told that the stock heads were good for this swap and the stock valve spings would be strong enough to put up to the lt1 cam i'm running comp cams manum 1.6 rocker arms and just want to kno if this combo will work and will i need major computer tuning if i install this camshaft any help is appreciated thanks .
Old Aug 1, 2007 | 08:18 PM
nelapse's Avatar
Car: GTA
Engine: 383 HSR
Transmission: TH-700R4
Re: LT1 CAM SWAP
Everything will work fine. Stock lift is .450 .450 for the LT1 cam, put 1.6's on it and it brings it out to .480 on the dot. This is the absolute threshold for your stock heads. I would strongly recommend a new set of springs to freshen up the heads.
However, if you can wing it, why not upgrade your springs and put in a better cam?
You can get some better springs and retainers, better cam and make much much more.
Old Aug 1, 2007 | 08:52 PM
Burnout91's Avatar
Car: '91 Z28 L98 G92
Engine: Modded L98
Transmission: Modded 700R4
Axle/Gears: Modded 10-Bolt
Re: LT1 CAM SWAP
Maybe even try the ZZ4 cam. .474 / .510 lift with 1.5:1 ratio rockers. Most will say (I believe) to machine the valve guides in the heads to accomodate the extra lift....but I trimmed the lower edge of the valve retainers (!) to prevent retainer / valve guide interference.....this is not the recommended method, but I did it. No probs with 40K miles of (HEAVY THROTTLE) use.
Bill
Old Aug 1, 2007 | 08:53 PM
1987ZTPI's Avatar
Car: 1987 IROC-Z
Engine: 310 lb9
Re: LT1 CAM SWAP
its a 97-98 lt1 cam and they ran 1.7 rocker ratio i belive so will that mean less lift since i'm using 1.6 ratio lift for thr 97 lt1 is 470=480 i belive
Old Aug 1, 2007 | 11:13 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: LT1 CAM SWAP
No, all LT1's use the same 1.5 stamped rockers as our cars. There is no 98 LT1 as GM switched to the LS1 in '98 f-bodies. The LS1's do have 1.7 rockers but they are not compatible with our engines.
No you will not need any computer tuning as the duration of the LT1 cam is very similar to the TPI cam.
However, if the valve springs are what came on the engine in 1987, I highly suggest an upgrade for those 20 year old springs. By now they're severely worn out and losing pressure. Something such as the GM LT4 springs, or our Manley 22409-16, 22410-16, or 22411-16. And replace your valve stem seals as well, so you wont get that dreaded puff of oil smoke on startup.
Old Aug 2, 2007 | 07:37 AM
1987ZTPI's Avatar
Car: 1987 IROC-Z
Engine: 310 lb9
Re: LT1 CAM SWAP
it puffs oil already , and the guy just said it was 97-98 he wasn't sure but as long as it will work without to much trouble then i'm happy thanks Ryan
Old Aug 2, 2007 | 11:32 AM
scuzz's Avatar
Car: 67 Firebird Convertible
Engine: LB9
Axle/Gears: 3.55
Re: LT1 CAM SWAP
If I'm not mistaken, I think the last three numbers will be 705 and stamped on the cam if it's a late LT1. The LT4 was 142.
1984HO
Mar 19, 2021 11:59 AM
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
Cameeeero
Sep 18, 2015 04:00 PM
dbrochard
Fabrication
16
Aug 19, 2015 06:21 PM
