Changing Fuel Filter
Old Jan 12, 2001 | 10:10 PM
wm_sorg's Avatar
Car: 1991 Formula Firebird
Engine: 2001 LS1 Modded
Transmission: 2001 4L60E Yank SS3600 TC
Hello All,
I am going to change my fuel filter tomorrow. Am I correct in assuming that I have to full the fuel pump fuse while the car is running to bleed-down the fuel pressure?
Should I still expect to get drenched when I am under the car. My tank is close to full will this make a differance?
Thanks,
William
91 Formula 305 TPI Stock
88 Formula 350 TPI Stock
Old Jan 13, 2001 | 07:00 AM
ede's Avatar
ede
i've never pulled the fuse, i open a fitting on the engine to bleed preasue. it's messy any way i've ever done it. there are rubber plugs made so you can cap off your line while you're getting the new stuff ready, or cleaning up.
ICON Motorsports
1st & 3rd
Old Jan 13, 2001 | 09:41 AM
theformula's Avatar
I've never bled the FP while changing the fuel filter, or while adjusting the FP.
You won't get drenched at all.
91 Formula
305 TPI 5speed
1LE/G92/WS6
K&N, SLP airfoil, ported/polished plenum, March pulleys, TB coolant bypass,Crane AFPR(47psi),Crane Gold 1.6rrs,MSD coil,MSD6AL, Holley 9mm wires, fastchip, Bosch O2sensor, SLP headers & catback,3:73s w/Auburn posi,160* t-stat,JET 195* fan switch, Macewen white face gauges, Autometer gauges, Zoom hi-performance clutch.
[This message has been edited by theformula (edited January 13, 2001).]
Old Jan 13, 2001 | 07:47 PM
89FormulaL98's Avatar
i did the fuel filter and tried to release the presure like you said, however for some reason the engine kept running it wouldnt use up all the fuel.... so i said screw it and just changed it.... got alota gas leaking but it was like it was spaying out or anything... just kinda trikled out
89' Firebird Formula WS6 L98, MSD 6AL MSD Blaster, Hypertech chip, K/N filter cone,flowmaster 80 series, hypertech air foil, koni shocks, edelbrock trailing arms
Old Jan 13, 2001 | 09:27 PM
wm_sorg's Avatar
Thanks who replied. Fortumately, I had a container to collect the fuel that pored out during the swap. I would say I lost about 14-16oz. I am sure the lawn mower appreciated it.
Old Jan 16, 2001 | 10:11 AM
KamaroZ350's Avatar
Car: 2008 Jeep Wrangler Unlimited
Unplug the battery, open the gas tank the relieve the pressure and you shouldnt get soaked in gas, but some will come out.
1991 Z28 Camaro L98
5.7L T.P.I
Blk ext/grey lthr int
http://www.fbody.com/members/KamaroZ350/
http://www.IROC-Z.org/3rdgen/BandetZ28-2-resized.jpg
Old Jan 17, 2001 | 09:17 PM
MrJ's Avatar
MrJ
I can't believe no one has mentioned this. Next time you do this, unplug the weatherpack connector for the fuel pump. It's located above the rear suspension. Just get the car in the air, get under it, and you'll see it if you look in the right spot. Once you do this, you can start the car and it will run for about 20 seconds and die. Crank it again to make sure there is no FP. Now you can do this with no fuel running all over the place. Just make sure that you don't have the car angled with the front end downward at all, or the fuel will run out of the tank and into the fuel lines due to gravity, and you'll make a mess.
91 Trans Am WS6
Bright White
5.0 TPI auto
Flowmaster 3" 2 chamber catback
Trans Go shiftkit
2000 stall converter
Built on Wednesday
Old Jan 19, 2001 | 12:36 AM
burnoutrpm's Avatar
ok are you guys really that afraid of getting a little gas on you , just wash it off or take a shower! hate to see what you do to change the oil
1989 firebird formula
Mods: converted from T.B.I. to a carburator 305 to a 350. Flowmater exhaust,hedman shortie hedders,202 heads,350 horse cam,bored.40 over, Edlebrock torker2 intake.
Future mods performer rpm air gap intake (polished) and 600 edlebrock carb, comp roller cam, and way better headsa 400 defintely in the works!
1992 Trans Am
May 10, 2023 07:19 PM
jklein337
Sep 19, 2018 06:23 PM
Infested
May 22, 2018 11:56 PM
Logan Bryant
Aug 27, 2015 11:52 AM
92camaroJoe
Aug 13, 2015 06:07 AM
