305 TPI intake on a 400 small block?
Car: 1991 Galant VR4
Engine: 2.0L 4G63 Turbo
Transmission: 5sp transaxle/transfer case
I'm getting an '88 IROC-Z with a 305 TPI. My friend's dad is wanting to sell a 400 small block complete with pistons, crank, and rods for $200. After having all those parts machined to freshen them up, I'd like to mount the TPI parts from my 305 on top of this engine. Would its air flow be enough or would it strangle an engine that size?
1986 Camaro
Carbureted 305
700R4
1986 Camaro
Carbureted 305
700R4
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
It'll strangle a 350 TPI, so yah it'll strangle a 400 as well. I'd say you need a SuperRam or MiniRam intake on that engine, but it depends on your choice of cam and heads.
West Coast GM Shootout 2001!
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
1991 Camaro Z28
13.25 @ 107.18 MPH
Southern California
Yeah, thats what I thought.
SuperRam isn't cheap, how much is Miniram?
1986 Camaro
Carbureted 305
700R4
1986 Camaro
Carbureted 305
700R4
About the same price: http://www.tpis.com/ has it.
yeah it'll work on a 400 but you need to do some updating to the tpi unit maybe new fuel ugrades, runner upgrades, throttle body a nd air foil. but i'd put a new air foil and throttle body on it and bigger injestors and regulator and it should be ok.
1989 firebird formula
Mods: converted from T.B.I. to a carburator 305 to a 350. Flowmater exhaust,hedman shortie hedders,202 heads,350 horse cam,bored.40 over, Edlebrock torker2 intake.
Future mods performer rpm air gap intake (polished) and 600 edlebrock carb, comp roller cam, and way better headsa 400 defintely in the works!
Car: 1989 IROC-Z
Engine: 383
Transmission: Pro-Built 700R4 2400 ACT Stall
Axle/Gears: 2.77 Borg Warner 9-Bolt
Yea, i agree it would probably strangle the engine, but a little porting work and some upgrades should tide you over until you can afford mini-ram or super-ram whichever you wish to get. Just don't expect your engine to breathe past 5500 rpms at most with the stock tpi, maybe even lower with a 400 (i'm not too familiar with 400's)
89 IROC-Z 350 TPI
-Flowmaster Catback
-Performance Resource Chip
-700R4 (Rebuilt) Too much done to actually list
-K&N Airfilters
-Ported Plenum
-2.77 Gears (not much to brag about but eh, its there)
-MSD 8.5 mm plug wires
-Problems every other day with the car (probably not a mod, but to me it sure makes a difference)
89 IROC-Z 350 TPI
-Flowmaster Catback
-K&N Airfilters
-Ported Plenum
does anyone have a list of what parts are needed, to make a 305 tpi intake work on a 400? i would guess
22 lb fuel injectors, instead of the 19 lb
afpr
ported intake
large tube runners?
fuel pump?
52-58 mm throttle body
air foil
anything i forgot?
also does anyone know if a factory chip will run this? maybe a 350 chip?
87 IROC-z 305 TPI 5spd Borg warner 9-bolt 3.45 posi 4 wheel disc,8.8 Accel wires , bosch platinum +4 plugs,gutted air box,k&n oil filter,synthetic oil 10w30
afpr
ported intake
large tube runners?
fuel pump?
air foil
anything i forgot?
Ever tried breathing through a straw while jogging?
87 Formula 350 14.61@94.07 before 2OTL, TCI stall, Nitto's, tubular LCA's & panhard
98 Z28 1LE 13.15@107.59
1LE Owners Association
Car: 1985 IROC-Z
Engine: Magnacharged LS1
Axle/Gears: Ford 9" 4:11's
Well, I had an Accel Superam base with SLP siamesed runners, ported plenum and a 48mm throttle body on mine last summer. It made lots of torque down low but by about 3500rpm it fell completely on it's face.....big time!
This year I am installing the complete Superam and a 58mm TB.
You will want at least 24lbs injectors also.
Fast355
Dec 2, 2016 06:33 PM
Sanjay
Aug 12, 2015 03:41 PM
