Stock chip help!!!
Old Aug 13, 2007 | 02:59 PM
TAtothefloor's Avatar
Stock chip help!!!
can some one please help me i need to know what the stock chip was that came in my car the part # and stuff i have a 89 trans am gta 5.7 automatic TPI (thats what the title says) but i have a cold start injector which i have read was done away with in 89. I need this info becasue i was going to order a chip from tpichips.com and the guy told me he needed the number off the stock chip and i went to go look at it and found i had a hypertech chip in the car i looked up that part # and the chip is for a 87
I realy need this bad becasue i need to diasable the vats so my car will start i just rebuilt the motor and i guess something got screwed up it will crank but not start some one told me it was the vats
all help is appreciated thanks
Old Aug 13, 2007 | 04:22 PM
Burnout91's Avatar
Car: '91 Z28 L98 G92
Engine: Modded L98
Transmission: Modded 700R4
Axle/Gears: Modded 10-Bolt
Re: Stock chip help!!!
On the home page of this site there is a section called "Third Gen Tech FAQ" that has a listing of stock PROM part numbers.
Bill
Old Aug 13, 2007 | 10:25 PM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
Sounds to me like you DO NOT have a 1989, but a 1987.
What's your VIN# (excluding the last 6 digits) so it can be confirmed that your car is indeed a 1989 with a 1989 TPI. There is a good possiblity that either the car is not a 1989 or the car had the engine/intake swapped.
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
Genopsyde
Oct 7, 2015 08:35 PM
bamaboy0323
Sep 3, 2015 06:07 AM
NBrehm
Aug 25, 2015 11:49 PM
NWAsonoma
Aug 18, 2015 05:45 PM
