New cam/head combo do i need a new chip?
Car: 88 IROC-Z
Transmission: TH350
Axle/Gears: 3.45
I am currently running a Hypertech chip in my car. This summer i will be going to a new top end setup. The bottom end will be stock still.
heres the new crap:
Dart Iron Eagle Heads, 180cc intake runners, 64cc combustion chambers
New cam: 278intake 286exhaust .450intake .420exhaust 108degrees of lobe seperation. 104degree intake centerline Gross Duration 312 Gross Exhaust 323
Harland Sharp 1.5:1 roller rocker arms
Manton Push Rods, stock length?
So the question is should i get a new ccustom chip burnt or is the hypertech i got good enough for now? Can the engine live with it and perform decently or will it run really bad? Need any more info? my buddy came up with that cam profile, hes used to dealing with higher HP crap but he tried a few different profiles. we got 375hp and 413ft/lbs. or torque on the desk top dyno. Thats about what im looking for seeing i still have a stock rear end and driveshaft. Thanks.
Kyle
1988 IROC-Z 350 TPI
(its an original 350 car)
License Plate: STG KLR 1
Engine Mods:
Edlebrock TES Headers, Hypertech Chip, Flowmaster Muffler, Intake Airfoil, Removed MAF Screens, bored .030 over, Other minor mods
Trans Mods:
2,500 stall converter, Redline clutches,Heavy Duty Steels, Trans-Go reprograming kit
, Heavy Duty 2-4 band, Corvette Servo, B&M Mega Shifter w/ Carbon Fiber Handle (looks sweet in a black car!)
Best Time So far: 14.104@99.66 Told you id go faster
"If you can put it on your car, its fair" Quote By Guido
Foundering Member of the Illinois Overkill Crew (IOC)
www.mfba.org
heres the new crap:
Kyle
1988 IROC-Z 350 TPI
Engine Mods:
Trans Mods:
, Heavy Duty 2-4 band, Corvette Servo, B&M Mega Shifter w/ Carbon Fiber Handle (looks sweet in a black car!)Best Time So far: 14.104@99.66 Told you id go faster
www.mfba.org
I don't think you NEED a custom chip, but if you have the money, by all means get a new one!
1987 Chevy Camaro IROC-Z
L98 TPI 350 (5.7L)
TH 700R-4 Transmission
Borg Warner 7.75" 9 Bolt Rear End
Current Mods: LT4 Hot Cam, Comp Cams 1.52:1 Roller Rocker Arms, Edelbrock TES 1 5/8" Headers, Hooker 3" Aerochamber Cat-Back System, Performance Resource Chip, Accel Ignition Coil, Cap, Rotor, 8.8mm Wires, K&N Filters, JET TPI Air Foil, All Free Mods, Falken ZIEX Z-Rated Tires.
Best ET (w/o LT4 cam): 14.32 @ 97.7mph
(corrected for elevation)
7.5" 10 Bolt with 3.42s soon to come!
L98 TPI 350 (5.7L)
108 LSA. I've heard that 108 is extreme for stock ECMs. 108 LSA will give you top end, but also will shake your teeth. Trust me on this one, I have 110 and it's pretty choppy, although it got much better with new 2100-2200 RPM converter. The chip is a Hypertech by the way, not much "tunning" there.
Rick
'88 GTA 350
Headers, catback, free mods, Xtreme energy cam, intake pieces and 2100 RPM TQ
13.40@102.55 MPH
1.90 Sec ------- Best 60FT
104.23 MPH -- Best Trap Speed
AIM HIGH!
Rick
'88 GTA 350
13.40@102.55 MPH
AIM HIGH!
That isn't a roller cam is it?
If your modding you 88 TPI then, correct me if I'm wrong but, don't you need a roller cam and you should have a lobe seperation no lower than 112*?
I think you'll need a custom chip but I could be wrong.
Ive never seen such a wierd cam profile. Are you sure thats right?
ANyhow, my 88 TPI was originally a 305 and now a 350. It sports every mod from TFS heads to a custom grind cam. Dont go too crazy with centerline. Keep it around 112. Yours is way too strange for a TPI motor. And yes you need a hydro-roller. And no, you dont need a custom burn. Mine is still running off the 305 STOCK chip and running 12.4 in the quarter. I realize i MIGHT hit high 11's with a custom burn, i just want to learn as much as possible about it and do it myself. Do more reserch on the cam.. I wouldnt touch yours... Hope this helps..
"Restore decency in America. Ban rice!!"
Moderator at www.Lastgen.com check us out!!
Car: 88 IROC-Z
Transmission: TH350
Axle/Gears: 3.45
ya that is a roller hydraulic, and ya it is lopey as hell. Its a custom grind, there are no manufacturer numbers or anything. We came up with that profile becuase it still provides good torque, but also wakes it up on top end where we all know that TPI's suffer. can anyone provide a cam profile that they think would still put out around 375hp and 420ft/lbs with the heads and everything? thanks for the help. im no good at cam selection, but my buddy is (at least he thinks so
) so he is the one who told me to run that cam.
) so he is the one who told me to run that cam. Trending Topics
To Run duration like that,and a LSA of 108*, Yes you need a custom chip.That Duration seems way to high for a TPI motor.Is this cam for a strip only car?You'll need a very high stall converter to put you in you powerband.
Nitro Don
Nitro Don
Car: 88 IROC-Z
Transmission: TH350
Axle/Gears: 3.45
The car is a Street/Strip car that is run on the highway a lot. It has a 2,800 stall converter. Does anyone have a recommendation for a better cam to run?
Car: 88 Firebird WS6
The hot cam will put you in that range even with crappy heads. With fastburns and flattops you get 430 hp, although the TPI would chop some off the top.
KO1
16
Oct 15, 2015 05:00 PM
