Camshaft for 305
Old Feb 12, 2001 | 12:34 PM
eatmydust's Avatar
Car: 1986 IROC-Z28
Camshaft for 305
What would be the benefits of getting a new cam shaft for my 305 tpi? Do I want anything else to go with it if I get a new or better one?
86' IROC-Z
5.0L TPI
Stock(for now)
Old Feb 12, 2001 | 04:05 PM
85F-body's Avatar
some new heads but they are hella expensive like $1g but that and some new springs and rockers
Old Feb 12, 2001 | 07:40 PM
ws6transam's Avatar
Car: 1984 Trans Am WS6
Engine: Minirammed 385, 396 RWHP
Axle/Gears: 3.73 Moser 12-bolt
You can port your own heads with about 25 hours of work. my ported 305 heads have brought me tantalizingly close to a 13 second quarter mile at nearly 101 MPH. See: http://www.isthq.com/~dan/ported.html
On the cam: Try a Comp Cams XE262H with 112 degree lobe separation angle. Don't get the 110 degree LSA; not enough vacuum.
Also get yourself a Turbine Technologies 2500 RPM stall converter for $165. It's a deal that'll chop 4 tenths off your quarter mile. At least, it did for me!
get yourself headers and a new exhaust if you havent already, along with an Edelbrock aftermarket intake manifold some aftermarket runners (I like SLP) and get your plenum ported. Stay with a 48MM throttle body for now; It'll support 320 HP easy.
I, uh, >ahem.< port plenums for $60 if you are interested.
Daniel Burk
http://www.isthq.com/~dan/fcar.html
'84 Trans Am WS6/L69
KB SFC, Moser axles, Torsen Diff. PST suspension, Braided stainless brake lines, Koni struts, 11-inch rear disks,Spohn Adj. torque arm,
Ported 305 heads w/1.94"intake valves, Comp Cams XE262H, Griffen alum. radiator,
Turbine Technologies 2500 stall converter, underdrive pulleys, Crane Hi-6 & more.
1.05g skidpad verified.
New best E/T! 14.039 at 100.82 MPH in 41 degree air at Stanton, Michigan.
GouldyGTR
Sep 7, 2015 09:05 PM
Stryker412
Sep 7, 2015 09:11 AM
TBRays98
Sep 6, 2015 05:05 PM
Formula_88AE
Sep 3, 2015 01:47 PM
willyjoejr
Sep 3, 2015 09:26 AM
