will a stock tpi run okay with the egr valve disconnected?
From: Newark,NJ> Where street racing on I 78 RULES!
I was planning on buying the mini ram set up & I was wondering if the EGR valve was just left disconnected, would the stock computer sense a problem & go nuts & make the car drive awful?
njdaewoo
406 sb
dart 200 heads(out the box)
144 B&M blower
373 gears
Edl headers
3in cat back Flowmaster exh.
270 comp cams
12.50s @ 115mph
on street tires
60ft time 2.30
www.njdaewoo@excite.com
New Project car
86TPI trans Am
All stock for now
njdaewoo
406 sb
144 B&M blower
373 gears
Edl headers
270 comp cams
12.50s @ 115mph
on street tires
60ft time 2.30
New Project car
86TPI trans Am
All stock for now
No, it will run just fine. The EGR is not part of the sensor system, it only cools the incoming air to the cylinders. Mine's been off for a couple years, and I get no codes or emission problems.
Car: '86 IROC-Z + Misc. project cars.
Engine: Supercharged + Nitrous TPI 355 CID
Transmission: Art Carr built Th700r4
The EGR being disconnected should set code 32!
There is an EGR diagnostic switch.
Its contacts are open when hot exhaust gasses are not flowing through the EGR valve and its contacts are closed when hot gasses are flowing though the EGR valve.
If the diagnostic switch is closed at start-up it sets code 32.
Also If the coolant temp is over 176°F ,and the commanded EGR duty cycle is over 48%, and the throttle position is not at idle or wide open, and codes 21, 22, 33 or 34 are not set, and all of these conditions are met for 4 minutes or more code 32 should be set.
If code 32 isn't set under the above conditions something is wrong or the EGR flag in the PROM is disabled.
The way around code 32 is a custom prom with the EGR flag disabled.
You can learn more about this on this sites PROM Board
Tracy /AKA IROCKZ4me
'86 IROC-Z Camaro
"Cogito ergo zoom"
EFI Performance Club on Yahoo
Club IROC-Z
[This message has been edited by IROCKZ4me (edited February 13, 2001).]
'86 IROC-Z Camaro
"Cogito ergo zoom"
- 355 cid
- AFR heads
- Arizona Speed & Marine hydraulic roller cam w/ AFR hydra-rev kit
- modified SLP runners
- TRW forged pistons/ceramic coated
- fully balanced
- Edelbrock headers/ceramic coated
- SLP cat-back
- Paxton supercharger
- Nitrous Express nitrous oxide
Club IROC-Z
Car: 1989 Camaro-1LE
Engine: TPI(s)
Transmission: 5 speed (MM5, MK6)
Axle/Gears: 3.45, 3.73
IROCKZ4me,
I thought that too, but my setup has proven different. I can't run EGR due to my edelbrock cylinder heads. So I figured I would just "fool" the computer, but I got the code 32. So I just unhooked the power lead that comes from the fuze box for the EGR and I never got the code again.
I can't explain why it does not give me an error other than without the +12 the whole circuit must be off and it does not check it. I am going to assume the check program has an "out" if some condition does not exist.
I never spent much time looking into this as I want to make a custom prom anyways.
This is a 1987 L98 stock prom. Go figure.
Mark.
Mark.
Guest
Posts: n/a
I disconnected the one on my 86 TA (took the vacuum line off) and it never set a code. Stock chip.
Another car, stock 88 chip, I eliminated the wires from the harness completely. It never set a code either.
Ive heard of people doing the same thing I did, and they got a code. I dunno if they did something different, or GM is inconsistent. I vote for GM being inconsistent.
Try it, see what happens.
1992rs/ss
Jan 31, 2025 05:10 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
