Stock vette heads, springs and lift numbers
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
My friend and I have basically stock vette heads. We both have bought cams with high lift numbers, not too high but up near .5 on intake and exhaust. I have a set of 1.6 roller rockers and he has a set of 1.5's. We are going to mix the set because if we use the 1.6's on the exhaust the lift is over .55. And using the 1.6's on the intake makes the lift just over .5 on the intake. My question is on the springs. What are the stock springs good for on lift. And if they arent good for just over .5 if we get new springs is the lift only dependant on the spring or a combination on the spring and the spring pocket or seat? So if we have to replace with new springs do we need to have the seats machined to make room so the coils dont bind?
James
If the women don't find you handsome they should at least find you handy
88 GTA Notchback with 91 gfx and ROH Snypers
Aftermarket T-56 (pain in the A$S but worth it)
Lots of things to do still
James
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Are they the L98 heads, or are they ZZ4 heads. The L98 heads have orange colored springs. They're good for about .520 lift. The ZZ4 heads have LT4 HOT cam springs, which are good to about .530 lift. I switched mine to a set of Manley 1.25" race springs, good to .540" lift, because they have better seat pressure. You should be able to get them from Jegs or Summit.
West Coast GM Shootout 2001!
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
1991 Camaro Z28
13.25 @ 107.18 MPH
Southern California
Car: 92 Firebird
Engine: 4.8 LR4
Well I know mine are orange, I remember thinking they were rusty looking but weren't. As fas as my friends I am unsure. I think they are going to be ok then, and if not we will only need to switch to LT4 hot cam springs.
1988iroc350tpi
Aug 14, 2015 07:52 PM
