L98 block
Old Sep 5, 2007 | 06:47 PM
afida15's Avatar
L98 block
i have a 89 iroc z with a tpi 350 its the l98 and i need new heads.what kind of heads can i use instead of stock? or is there a crate motor that will bolt wtih my intake manifold for the fuel injection?
Old Sep 5, 2007 | 07:45 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: L98 block
pretty much any head designed for '87-up small block chevys and fits a 1204-1205 gasket size. cant use vortecs or any vortec style head with factory base tho
good cheap upgrade is the corvette Aluminum L98 head. need a vette manifold or drill your two center bolt holes on both sides in the current camaro manifold straight up to use corvette heads
ZZ4is probly the most popular crate motor that will bolt to TPI
Old Sep 5, 2007 | 08:14 PM
afida15's Avatar
Re: L98 block
so any ZZ4 motor will work with my stock TPI intake and all that stuff?.. will ZZ4 heads work with a regular block?
Old Sep 5, 2007 | 09:51 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Re: L98 block
yes, ZZ4's have modified L98 vette aluminum heads...basically setup to handle more lift of the ZZ4 cam which is a mild cam that does well in TPI stock motors. computer will handle it fine too without tuning but tuning will help gain more power
Old Sep 5, 2007 | 10:01 PM
boldguy's Avatar
Car: 1992 Z28
Transmission: World Class T-5 5speed manual Trans
Axle/Gears: STOCK G92 performance 3.42
Re: L98 block
This weekend im getting a set of ZZ4 alumminum heads, brand new for $725.
they are the same casting as the L98 heads 10088113
Prodigious
Theoretical and Street Racing
35
Apr 13, 2021 02:37 PM
3GZJerry
LSX and LTX Parts
Oct 14, 2015 05:17 PM
86z89iroc
Oct 5, 2015 01:04 PM
Tarizza
Sep 24, 2015 12:57 PM
RyanJB
Sep 14, 2015 03:39 PM
