Cutting Out
Old Feb 22, 2001 | 04:03 PM
zmy28's Avatar
Cutting Out
1985 Z28 305tpi. Wants to cut out at initial acceleration and periodically at higher speeds, also sometimes surges (rpm's flucuate)at de-acceleration....new fuel pump - problem existed prior to new pump install......any ideas, thanks.
Old Feb 23, 2001 | 11:31 AM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
You probably should replace the fuel filter as well.
If problem persists, you may want to look into the iginition...PU coil, reluctor, module, cap and rotor, etc....
Old Feb 23, 2001 | 11:43 AM
R.O.B.'s Avatar
A good tune-up and fuel filter is in order. Also, when was the last time you replaced the O2 sensor? This should be replaced every 30k miles. If you have TPI, look at the TPS sensor. See if it is set correctly, and check the sweep of it, to see if it has a short.
Rob
'86 TA 305 TPI
Gutted MAF
Ported Plenum
TB Bypass
Old Feb 23, 2001 | 04:11 PM
The ODB's Avatar
man, anything with the old MAF sensor and I'd have to suspect that first, even if the engine had an obvious gaping hole in it.
no, I don't know with just that info & no testing, but MAF's can be flakey and cause intermittant problems.
Old Feb 24, 2001 | 09:24 AM
LeeH's Avatar
Car: 89 Firebird Formula
Engine: 389
Axle/Gears: Moser 4.11
Yeah, especially that weatherpack! That caused me so much grief because one little female connector in there was ever so slightly out of shape. Something you can't tell when you backprobe the wires...
MoJoe
Members Camaros
33
Feb 6, 2025 09:47 PM
SRKLEGIN
Interior Parts Wanted
Oct 12, 2015 07:28 AM
gord327
Oct 3, 2015 01:25 PM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
SRKLEGIN
Sep 30, 2015 07:19 PM
