TPI Throttle Body Coolant Passage
Old Sep 10, 2007 | 05:52 PM
1 DwnCam's Avatar
Car: 92 Z28 Camaro
Engine: Procharged 406.
Axle/Gears: Moser 9" 4.11 Gears
I have a BBK 1539 TB and I just bought a Billet Specialities Water neck. The water neck will work with out the coolant passage attached to the TB. Can I make a block off plate or will this cause other problems? The TB is for the 1992 5.7 Motor. The reason I ask this question is because I misplaced the coolant housing to the TB and I can't remember if it has the IAC attached to it?
Old Sep 11, 2007 | 01:00 PM
formula_novice's Avatar
Car: 1989 Firebird Formula
Engine: 383 Stealth Ram
Axle/Gears: 3.73 9 bolt Posi
Re: TPI Throttle Body Coolant Passage
I'm not sure I completely understand your situation,
but you can bypass the coolant passage in the throttle body.
Check out this link for instructions...
https://www.thirdgen.org/coolantbypass
Hope this helps!
Old Sep 11, 2007 | 11:48 PM
1 DwnCam's Avatar
Car: 92 Z28 Camaro
That is very interesting. Thanks for the link. My original question was if i could do away with the coolant passage all to together (physically remove it from the Throttle Body). I wanted to know what adverse reactions this would cause. The diagrahm from the link shows that the IAC is attached to the coolant passage, so I guess that is a negative on removing the housing all together.
1992 Trans Am
May 10, 2023 07:19 PM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
bamaboy0323
Aug 15, 2015 07:20 AM
ZZ42Fast
Aug 10, 2015 08:20 PM
