Top Speed Run??
Old Feb 26, 2001 | 04:48 PM
GTA's Avatar
GTA
Car: 1992 GTA
Engine: running
Transmission: working
Axle/Gears: both
Top Speed Run??
Hi, has any one ever run there GTA or Iroc
\Z28 (radar run of course) and I'm mostly
interested in a bone stock L98, but the Lb9's
are welcome too! I've been told that they
will come close to 155 or so, but i could be
wrong. Later -GTA
Old Feb 26, 2001 | 05:47 PM
GTA Notchback's Avatar
Car: 88 GTA Notchback
Everything I have ever read on them best I can remember said the stock 350 GTA would run 141 mph and a stock 350 IROC would run 145 mph.
Have not had mine that fast myself so dont know for sure.
Old Feb 26, 2001 | 06:17 PM
vortech305's Avatar
I dont know if u care about a 3.1 but i tried it in my 3.1 camaro and hit 125 with just a k&n air filter.
92' camaro
New 305 block TPI conversion, Forged parts all around,Edelbrock intake,ported plennum,ported corvette alluminum heads, accel cam,52mm throttle bodie, SLP runners,ford SVO 19lb injectors,fuel regulator,cloys timing chain, comp alluminum roller rocker arms and pushrods MSD 8.5 mm wires, bosch plattinum plugs, hypertech cap & rotor and coil, Edelbrock TES headers, free flowing catalytic converter and a 3 inch force II flowmaster exhaust system.
Soon to come!!!
Procharger system 12lbs o boost.
Favorite quote: "where ever u go, there u are"
Other car;
1971 plymouth Duster
Mods:340,edelbrock victor jr. intake, 650 4 barrel holley, heddman headers,40 series dual flowmasters, cold air intake,4:10 gears, just got a new paint job and cragar rims with 315 tires in the back.
:Yeah its not a chevy but damn how many 71' dusters have u seen in the streets.
Old Feb 26, 2001 | 06:20 PM
The ODB's Avatar
I know of a stock L98 (aluminum heads) 1989 Formula-350 that went 152mph.
This was in 1990.
Old Feb 26, 2001 | 06:35 PM
sparks383iroc's Avatar
Car: Mullitt mobile :)
Engine: it's stock LOL
Transmission: 700rJunk
Axle/Gears: 2 much 4 street not enough for strip
I don't know how accurate the speedo was (car only had 11k on it), but somebody had my '89 L98 pegged against the trip reset button on the 145 mph speedo (figured it was going over 150).
Sparks a flyin'
[This message has been edited by sparks383iroc (edited February 26, 2001).]
Old Mar 2, 2001 | 12:18 AM
evilho7810's Avatar
An 87 I-ROCZ was run at 149mph in an old car and driver.
Old Mar 2, 2001 | 05:44 AM
98_1LE's Avatar
I'm confused. Do they shift into OD under WOT? Because if not my 3.27 car would run out of useable rpm before it went 140 mph ODB, did aluminum heads come stock on an F-body???
87 Formula 350 13.94@96.67
98 Z28 1LE 13.15@107.59
1LE Owners Association
Old Mar 2, 2001 | 05:57 AM
bjankuski's Avatar
Car: 1988 Firbird
Engine: 406
Axle/Gears: 4.10
98_1LE,
Alum heads did not come stock on GTA's or IROC's.
Some IROC's and GTA's will shift into overdrive at full throttle. I have a 1987 350 GTA that came stock with 2.77 gears. That gears have been switched to 3.27 gears and it will shift into overdrive at 110 MPH.
1988 Formula 5L/5sp 3.45 gears, SLP cold air kit, MAS gutted, TPIS air foil, TPIS AFPR, MAC headers, Mac under drive pulleys, MAC cat back, Relocated MAT.
Best ET street tires 13.85
Best 60 FT street tires 1.930
Best MPH street tires 99.29
Old Mar 2, 2001 | 10:19 AM
Greg90iroc's Avatar
i know that 140 comes pretty easy and with out too much effort in my car. I accidentaly hit 140 and did not realize i was going that fast. I was still accilerating pretty good too. but why the hell do you want to go that fast. It is scarry when you hit speeds like that.
90 IROC l98
last season best corected 13.62 @102
mods
full exhaust, AFPR, pulley, jet stage 1 chip, billet servo, 52mm throttle body, slp runners and some 1.6 RR's and a few other little things.
243 RWHP and 342 RWTQ with hot engine and 90 octain fuel
Old Mar 2, 2001 | 03:52 PM
The ODB's Avatar
yes a friend of mine that I worked with ordered his formula 350 with aluminum heads and dual cats.
It came with the heads but only a single cat. Then one of his heads cracked and when it was back at the dealer getting a new head they put on his dual cats. It would run mid 14's @98 without changing anything at all on it. Not too bad for back then.
ODB
[This message has been edited by The ODB (edited March 02, 2001).]
1992 Trans Am
May 10, 2023 07:19 PM
Poncho92
Group Purchases
Aug 25, 2015 02:17 PM
InfinityShade
Aug 22, 2015 08:00 PM
kyleb24
Aug 15, 2015 08:24 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
