Driving me up the wall!
Old Mar 5, 2001 | 12:49 PM
88gta305's Avatar
Car: 77 Corvette
Engine: ZZ3/nitrous
Transmission: THM 400
This problem is driving me crazy. Around town I get no SES light. But on the highway, after 14 miles or so, on comes the light with codes 32 and 36. If I stop, and wait a while, restart, the SES light stays out, until I drive about 14 or 15 miles again.
Help, this is driving me nuts.
Cheers
Richard
Old Mar 5, 2001 | 07:52 PM
Kevin Irving's Avatar
Car: 1985 Trans Am
My best guess would be that something is either loose or heating up to the point where a connection in your MAF system is losing electrical contact due to heat, vibration, or corrosion. I would check all your weatherpack connections at the TPS, MAF, and MAF power and burnoff relays and all their wiring to make sure you aren't shorting anything out. Clean all the connections with alcohol and/or a jeweler's file, and go ahead and replace the two relays, they are only about $11 apiece at the dealer.
Kevin Irving
85 Trans Am WS-6, 305 TPI, custom burned '86 PROM with '87 "165"ECM, Accel Supercoil & 8.8 Wires, MSD 6AL, Aluminum Driveshaft, TB Coolant Bypass, Ported Plenum, Modified MAF, Syclone Fuel Pump, JET Airfoil
15.556 @ 86.65mph, Nov 10, 2000.... I know it sucks.. but it will get better!
http://www.geocities.com/transam85tpi/
[This message has been edited by Kevin Irving (edited March 05, 2001).]
Old Mar 5, 2001 | 09:24 PM
james_fearn's Avatar
The same thing happens to me. After driving on the freeway above 60~65 for more than 12 miles (or so) my check engine light comes on. There is no difference what-so-ever in the running quality of the car before or after the light comes on. When I restart the engine the light doesn't come on. When I check for codes none come up. I've asked this question on the board before and it seems that a lot of people have this problem.
If you find out what is causing it let us know. It may be some kind of stupid speed warning or something. Kind of like putting an 85 MPH speedo in a freaking camaro. What were they thinkin'.
James
1985 Z-28 305 TPI
221,000+ mi., Original Eng.
[This message has been edited by james_fearn (edited March 06, 2001).]
Old Mar 6, 2001 | 07:43 AM
88gta305's Avatar
Car: 77 Corvette
Engine: ZZ3/nitrous
Kevin,
Thanks for the reply, I will replace the relays, and check the connections, and James
I will let you know if I find out, and yes, it makes absolutely no difference to the performance when it comes on.
Cheers
Richard
Old Mar 6, 2001 | 08:41 AM
vortech305's Avatar
I dont know if this helps but my friend had the exact same problem with his 89'Z and he checked every part of the motor nothing was wrong. All he did was disconnect the battery wait for 5 minutes, put the battery cables on and the light went away. The car must of stored the problem in its memory from the guy who had the camaro before u.
92' camaro
New 305 block TPI conversion, Flat top pistons,Bore over .30 Forged parts all around,Edelbrock intake,ported plennum,ported corvette alluminum heads, accel cam,52mm throttle bodie, SLP runners Home aid cold air induction, Air foil,ford SVO 19lb injectors,fuel regulator,cloys timing chain, comp alluminum roller rocker arms and pushrods MSD 8.5 mm wires, bosch plattinum plugs, hypertech cap & rotor and coil, Edelbrock TES headers, free flowing catalytic converter and a 3 inch force II flowmaster exhaust system, and a 3 inch cutout,Zoom multi friction clutch, T-5 tranny,billenstien shocks&struts.
Soon to come!!!
Procharger system 12lbs o boost.
New paint job(hawaiin orchid purple)Cast alluminum ZR1 rims w/ 275 tires.
Favorite quote: "where ever u go, there u are"
Other car;
1971 plymouth Duster
Mods:340,edelbrock victor jr. intake, 650 4 barrel holley, heddman headers,40 series dual flowmasters, cold air intake,4:10 gears, just got a new paint job and cragar rims with 315 tires in the back.
:Yeah its not a chevy but damn how many 71' dusters have u seen in the streets.
Old Mar 6, 2001 | 01:18 PM
HighHorseZ's Avatar
I have the exact same problem with my 86 Z28 305 TPI. It didn't start happening until after I got my exaust done (headers, no cat, 3 1/2" to Flowmaster w/ dual 3" out). Could this problem be attributed to lack of back pressure?
86 Z28
305 TPI
3.73, Flowmaster, TPIS Air Foil, Headman Headers, March Pulleys, K&N, Hypertech
Old Mar 6, 2001 | 01:27 PM
Omega's Avatar
Car: 89 Formula / 09 G8
Engine: LS1 / LS3
Transmission: M6 / M6
Axle/Gears: 3:42 / 3:27
My 89 did the same thing, but also liked to stall after crusing for a bit then stopping. I pulled the codes and it said it was the EGR (code 32?) I changed the O2 sensor and it hasn't happened in almost a year.
If i were you i would change the 02 sensor and if that doesn't fix it, replace the EGR
[This message has been edited by Omega (edited March 06, 2001).]
Old Mar 6, 2001 | 01:44 PM
I have stock everything including exhaust. Even after I replaced the O2 it still happens. My EGR functions normally although it is original.
James
evilstuie
Jan 9, 2020 08:29 PM
gta90
Sep 15, 2015 04:00 PM
86IROC112
Aug 21, 2015 12:39 PM
IroczFan
Carburetors
Aug 18, 2015 05:19 AM
