Where do I check TPS voltage?
Car: 89 IROC convert.
Engine: tpi 305
Axle/Gears: 3.42 10 bolt
OK I've got the instructions for checking the TPS voltage on my TPI, but there are three wires coming out of the thing. Which wires do I put my VOM on?
Engine: tpi 305
Re: Where do I check TPS voltage?
C'mon you guys. I know you know this. I need to get this car sorted out this weekend.
Pleeeeeeze.
Pleeeeeeze.
Car: 87 Iroc Showcar - Saturday Nite Hun
Engine: 383 4-Bolt Truck Hyd Roller MiniRam
Transmission: B&M 700R4 - Edge 3200
Axle/Gears: BW 9 Bolt-TA Cover & Stud Kit - 3.2
Top Two
.540 closed- over 4.00v open. Think applies to yours.
Smooth linear increase as you go from closed to full
open.
HTH
Later
open.
HTH
Later
Car: 1983 G20 Chevy
Transmission: 4L60
BLACK and BLUE, should be around .60 with the key on, engine off and the throttle closed. It should be up around 4.50 volts with the key on, engine off and the throttle Wide Open. I cheat on the TPS settings slightly, to make the TCC unlock sooner and bring in the Power Enrichment (PE) fuel and timing faster.
Engine: tpi 305
Well I don't claim to be any genius with a VOM, but it appears that I have zero voltage from the TPS. With the key on, but engine not running, I checked the voltage for each terminal in the connector to ground. The top one had .02 volts, the middle terminal had about .05 volts, and the bottom had about 5.5 volts. running through the TPS, the voltage is 0 with the probes on the top two jumper wires.
What up?
I'll go check the colors.
What up?
Engine: tpi 305
Directly checking the voltage across the blue and black wires with the key on, I get .03 volts.
I gotta bad feeling about this.
mdtoren
Aug 16, 2015 05:45 PM
db057
Aug 11, 2015 10:11 PM
