Valve seals gone early?
Old Mar 4, 2001 | 04:50 PM
SpankuGta's Avatar
The motor in my car has 73,021 miles and the valve seals are gone,it dont smoke till i get on it or when i first start it,have any of you done valve seals that have gone early? if so what kind of seals did you put in the heads?
88 GTA 73k miles
Flowmaster catback,Random tech high flow cat,Ported plentum,Hypertech afpr and air foil,cold air induction,Msd blaster ss coil,cap and rotor and Super Conductor wires.Best ET 1/8th 9.21 at 77 mph.All mods were done within two weeks after purchase.
Old Mar 4, 2001 | 05:03 PM
98_1LE's Avatar
Sounds about right to me. Anything rubber just dries up down here! I bought my '87 last year with 42,500 miles and it smoked when it's starts. It's at 53K now and still smokes when it starts I'm planning a ZZ4 head (and cam just for good measure) swap to cure the problem
87 Formula 350 13.94@96.67
98 Z28 1LE 13.15@107.59
1LE Owners Association
Old Mar 4, 2001 | 06:00 PM
JETHROIROC's Avatar
Mine did the same thing when I first bought it. I just picked up a set of Fel-Pro seals from Advance auto and fixed it. No smoking anymore .
Old Mar 6, 2001 | 12:49 AM
SpankuGta's Avatar
Did you pull the heads off or do it on the car?I am going to try doing it in 2 days with the heads on the car.Ill post back wed night,thanks for repling.
88 GTA 73k miles
Old Mar 6, 2001 | 09:59 AM
JETHROIROC's Avatar
I would definitely do it with the heads in the car, unless you're planning other modifications or new valve guides or something. I did mine with the heads in the car and didn't have too much trouble. Make sure you use a magnetic tool or something to hold onto those little keepers or you may have to pull the heads. Good luck!
Old Mar 8, 2001 | 11:32 PM
SpankuGta's Avatar
I am planning on doing it saturday along with a zz4 cam i got from scoggin.Anyone with the ZZ4 cam out there what springs did you use?
88 GTA 73k miles
Old Mar 9, 2001 | 06:30 PM
JoelOl75's Avatar
Car: 88 Firebird WS6
For a 1.250" (stock spring) on my ZZ4 cam with 1.6 rollers I used K-Motion model 750 springs. 130# on the seat (1.7" installed height) #380 over the nose and lots of room before coil bind. They're pricy though at $126 a set from summit, but thats alot of lift to punish a 1.25" spring with. They're made from H-11 tool steel wire (better than silicon) and hold their # rating much longer. Cheapies out there might work for awhile but....
Retainer to guide clearence will have to be machined for this cam. Even with 1.5 rockers. And if you do this, you might as well have them machined for larger springs which will be cheaper!
Old Mar 10, 2001 | 07:43 PM
SpankuGta's Avatar
A salesman at Scoggin-Dickey told me to use the Lt4 Hot cam springs they are only $69 for the springs,retainers and locks.
88 GTA 73k miles
Bubbajones_ya
Jul 6, 2024 08:32 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
tgp1990
Sep 4, 2015 06:24 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
