tps taking a crap on me???
Old Mar 5, 2001 | 11:15 PM
hookin88formula's Avatar
wheni pulled up to a stop light tonight the car seemed to want to stay idleing at around 1500 rpm and when i held the brake and tapped the gas pedal just a bit it idled down. could this be the tps going out on me? or could it be the tv cable? its almost like it wont kickdown and when u rev it a bit it will idle down thanks for all the help!
1988 firebird ws6 formula350tpi msd 6al box blaster 3 coil accel 8.8 race wires hooker shorty headers hooker cat back system pro shift light a pillar gauge pod and water temp and air/fuel ratio gauges autometer oil pressure gauge b&m mega console shifter, march underdrive pullies, tpis airfoil cvr high torque starter (love it)
best 1/4 mile run of 14.44@ 96.53
this run is before the new exhaust system
Old Mar 6, 2001 | 12:07 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Sounds more like your MAF sensor could be dead, or you could have a vacuum leak.
West Coast GM Shootout 2001!
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
Old Mar 6, 2001 | 12:25 PM
god i hope it isnt my maf going bad.. u think its the sensor or the hole maf? how do i find vacum leaks?
Old Mar 6, 2001 | 05:10 PM
JETHROIROC's Avatar
Grab a can of carb cleaner and spray around all the vacuum hoses and their connections, throttle body gasket, runner gaskets, etc. If the engine idle changes any when you spray a particular area, there's your leak. Hope this helps.
Old Mar 6, 2001 | 08:34 PM
BP89IROC's Avatar
sounds to me like a binding throttle cable or crudded up throttle body. Unless i'm misunderstanding somthing.
Old Mar 7, 2001 | 12:24 AM
ok thanks guys i am taking the plenum off wednesday anyways so i will check the throttle cable if its binding what do i do? and i will lean the tb out i pln on polishing it anyways. thanks for the guys if that doesnt do it i will check back.
Old Mar 8, 2001 | 08:49 PM
precision350's Avatar
A while back my car was doing the same thing. Turns out it was a bad throttle body. Try to move the throttle arm back and forth (twards the front to the back of the car). If it moves then the TB is bad. There is a lifetime grease inside the throttle body to lubicate the shaft and if you spray carb cleaner or any other kind of caleaner not designed for use with this grease, it will remove it and cause the TB to wear out.
92 Camaro Z28
350 TPI
Dart Iron Eagle heads
10.5:1 cr
52mm throttle body
Ported plenum
Home made AFPR ($2)
1 5/8 shorty headers
Ram air
2.5 inch TRUE DUAL exhaust (no cats)
Flowmaster mufflers
4.10 gears
700R4 w/2000 stall
100HP nitrous
Best time befor any of these mods:
15.1 @ 91.9
Best time after mods:
12.60 @ 108.3
That is at high alt.
5600 feet Morrison Colorado Bandimere Speedway
Old Mar 9, 2001 | 04:00 PM
355 IROC-Z's Avatar
have you tampered at all with the idle air screw at all?? just wondering
Old Mar 11, 2001 | 02:56 AM
nope never screwed with the iac but i did the tps i have my plenum off and polishing it right now i also got new runners so once i get it back together i will mess with it more.. this is really stumping me what it is i think i will mess with the tps and see if that does anything.. i cant believe that a tb can go bad but i have heard of weirder things i guess.any one else heard of a tb going bad?
92camaroJoe
Jul 29, 2023 07:57 PM
83 Crossfire TA
Jan 3, 2016 01:26 PM
Gunsbee
Sep 7, 2015 07:10 PM
92camaroJoe
Aug 13, 2015 06:07 AM
